Old 6th January 2010, 07:11 PM
badger7777
Guest
Posts: n/a
Default ESP switch
So, with all the snow lying around, is it best to turn off the ESP or leave it on? Does switching it off have any influence on the ABS system too?
Old 6th January 2010, 09:21 PM
If you're sensible, with quattro it makes little difference to be honest (have played around with both on and off).
Old 6th January 2010, 10:08 PM
I Don't think the ESP alters the ABS. Just leave it on, and play.
This as great opportunity to discover what can do
Old 7th January 2010, 07:25 AM
ABS can't be turned, only a fault in the system (eg faulty sensor) or pulling the fuse to the ABS controller would stop it working...
ESP is probably worth leaving on as it will deal with situations where one wheel hits ice and the other 3 are still good to go.
Agree that when driving sensibly there will be little in it, but lets face it, we all like to nail it a little and see what happens in this weather, and with ESP on you should pull off quicker in a safer straight line....
Old 7th January 2010, 09:15 AM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
leave it on = get to where ur going
turn it off = get to where ur going with lots of sideways fun
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 7th January 2010, 07:15 PM
badger7777
Guest
Posts: n/a
Had half an hour to kill this evening so been for a test on an empty snow-covered carpark. As PsYcHe said, not much difference with ESP on or off if you squeeze the throttle gently, but deffinitely more sideways action when you stamp on the loud pedal:ROFL
Think i'll be leaving the ESP on while there's snow lying around then
Old 7th January 2010, 07:52 PM
ChriS8 ChriS8 is offline
Don't even have that button, which is good
Now playing: Green Day - Longview
via FoxyTunes
Audi S8 manual, 1996 <- much fun
Kawasaki ZX9-R 2001 <- much more fun
always remember:ficken!
Old 7th January 2010, 10:09 PM
ESP research day. Thorough testing in narrow lane that is currently one long sheet of ice with the odd dry patches.
ESP on, heavy right foot = Lots of interesting twitches, rev counter action, sudden huge bursts of acceleration.
ESP off, heavy right foot = very Very exciting, learned how long and 8 is and how narrow that lane, oppy lock comes kinda natural when the alternative is a trip into the scenery.
Conclusions
1/ No ESP is almost to much fun with all that power
2/ ESP on a low friction surface = very quickly reaching a high speed... on a low friction surface, where ABS is about as much use as a pork pie at a
Bar Mitzvah.
