Old 27th July 2016, 10:47 AM
Albert_Swafega Albert_Swafega is offline
Default Suspension Fault
2011 A8 3.0 rear has dropped, needs fixing quickly, so dropped in at the Dealer, but they can't look at it until tomorrow.
Just wondered if anyone had had this before or could give a reasonable guess as to the cause/remedy?
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008001
Shop #: WSC 01236 210 01865
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_AU64.rod
VCID: 2CB2C93F4F04AF724986B1-8078
6 Faults Found:
677386 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 197
Mileage: 171307 km
Date: 2016.07.25
Time: 18:30:20
677387 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 197
Mileage: 171305 km
Date: 2016.07.25
Time: 17:57:45
677390 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 171232 km
Date: 2016.07.20
Time: 20:46:57
403200 - Function Shut-Off Active
C10C8 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 157
Mileage: 169652 km
Date: 2016.06.20
Time: 18:44:14
677124 - Ride-Height System
C1047 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 171294 km
Date: 2016.07.24
Time: 18:21:36
115968 - Functional Limitation due to Excessive Temperature
P178E 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 197
Mileage: 171307 km
Date: 2016.07.25
Time: 18:23:57
2011 A8 Executive 3.0 TDI Quattro
