Old 24th August 2020, 01:03 PM
Regulus Regulus is offline
Default Oil cooler, gaskets on a 32V
077 115 401b is the part number on my oil cooler.
Does anyone know what the gasket part numbers are?
I ordered a kit because that was the only I found with the gasket that looks like an 8, even if it warned me that it didn't fit my car. The 8 gasket is almost correct, but not quite. It was worth the try, as it was shipped with the cam belt as well.
https://www.autodoc.co.uk/ajusa/1384...20%20(77001700)
The plastic pipe broke off when I tried to pull it out. But I have the metal pipe, so hopefully that will fit at least
ID:	23800   Click image for larger version
ID:	23801   Click image for larger version
ID:	23802   Click image for larger version
ID:	23803   Click image for larger version
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
