Hi guys,
It seems that I have a problem with swirl flaps on one side. There is some oil leak on the gasket on the right side of the intake manifold. What do you think is it a gasket, a carbon buildup, swirl flaps that are failing or a combination of all of the above? Also, there is a check engine light ON which points to the left throttle body. Any help would be appreciated! Marko |
