Old 12th June 2023, 10:37 AM
Default Potential HVAC problems - how to diagnose?
I have two potential problems, neither currently an issue, but "a stitch in time" as they say:
1. The solar sunroof intermittently is just not working. (Today it is)
2. VCDS scan of HVAC, Fault Found: 00716 - Air recirculation Flap Positioning Motor (V113) 41-00 - Blocked or No Voltage. (This fault returns immediately if cleared)
There is no discernible pattern to the sunroof issue, if it's working, even on a grey day, it's vigorous. It had a new HVAC fan motor last summer.
But where to start on prodding, poking, measuring and diagnosis? My understanding (from long ago so could be wrong) is that the switchover is done by a relay WITHIN the HVAC, so the external wiring is very simple.
I did once fit a simple override (cutoff) switch in the (earth leg of the) sunroof circuit but MJ reverted that to OEM last summer as it wasn't the best quality job.
I normally run with the auto-recirculate on and haven't noticed anything odd. The air quality sensor was showing a fault long long (years) ago but I dismantled and cleaned it and it's always been fine. Again, I understand that there are procedures that can exercise/test/reset the HVAC flaps more thoroughly, but is that advisable and how best to do it?
