Go Back   A8 Parts Forum > A8 D4 > D4 - Interior Electrics
D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc
Old 8th September 2023, 08:20 AM
Saff Saff is offline
Default Reversing camera.
Hi, sorry if this has been posted on before but I guess too much info is better than none.
The reversing camera on my D4 has been a bit hit and miss for some time now, sometimes working and sometimes not. Yesterday it flashed on and off a couple of times before choosing to be 'off' .
Obviously a poor connection I googled it and found it to be a common issue on all Audi models. A fix being to unplug and re-plug a connector. On the D4 a common culprit resides in the fusebox in the boot, the one in the trim over the rear seat back. Remove the plastic cover and the connector is bottom left hand corner.
Against advice to unplug and re-plug mainly due to awkwardness to reach in I just 'wiggled and firmly pressed' the plug. To my delight the camera now works fine. Fingers crossed and I hope it may help others.
2010 D4 SE Executive 4.2 TDI
