For Sale and Wanted - Cars For the sale of whole cars, Audi or not, working or not. No cross links to other peoples cars please - Use Spotted online instead |
Firstly apologies to the regular members on here, I can appreciate it's annoying when an infrequent user pops up and is trying to sell something. However, maybe someone on here may benefit from this.
Quick summary Audi A8 D2 3.7 Quattro Reg Y512JAE - If you want to check the MOT history Mileage - 160,782 Its had 30k spent on it since purchase, on servicing, parts, paint and repairs! Including a rebuilt engine (2010) and a rebuilt gearbox (2015) More recently front shocks and springs, lower suspension arms, battery Car is genuinely in good condition Non-runner £500 - Car needs to be trailered away. Background The car is a non runner - Aux pulley failed, also suspected fuel pump failure. The car was recovered after the aux pulley failed. The AA guy drove it back on battery power alone, which may have killed the fuel pump. I actually had to recover the AA guy and my Dads car after he did this! The car hasn't started since (see codes below). Before then it ran and drove really nicely. Symptoms seem similar to how the car was the last time the fuel pump failed. This is my Dads car, he is reluctant to see the car go but he has a new car for daily use and is now having to downsize so losing his driveway space. Honestly, he is keen to see go to a good home or be used for parts to keep some other A8 on the road rather than being crushed. I have repaired the car in the past for Dad, but I don't have the free time to commit to it to get it back on the road. As nice as it is I don't have a use for it and neither does Dad. Here are the issues Codes showing 17521 - Lambda B1 S1 16814 - Catalyst system B2 low Sig 16711 - Knock sensor low sig 16946 - System voltage to low 17536 - Fuel trim B1 lean 17538 - Fuel trim B2 lean 16684 - Cylinder misfire unknown 16685 - Cyl 1 misfire 16686 - Cyl 2 misfire 18010 - Power supply B+ terminal 30 voltage low Other bits I know about Broken Aux pulley tensioner Dead fuel pump AC doesn't blow very cold CAT rattle on start up Slight leak from PS lines Parking sensor flat lines (new sensors included) Car would need to be collected on a trailer. Location, just outside of Weston super Mare. All the images are here. https://drive.google.com/drive/folde...oy?usp=sharing Happy to field any questions. Thanks James Last edited by jamesb; 21st August 2024 at 08:20 AM. |
