Go Back   A8 Parts Forum > Our Other Audi Friends > A2 8Z
A2 8Z 2000-2006
Old 5th September 2022, 04:03 PM
Nognar Nognar is offline
Default Audi A2 - Long Crank when Warm
Ladies and Gents,
I know its an A8 forum but I am not getting much from the A2 forums on this one and its causing me a real challenge on working out what it going on with the little runabout.
So I thought I would ask the collective for your thoughts, as you will see I have done a lot already to try and work this one out!
Car is a 2001 1.4 Petrol AUA, 114,000 miles and drives perfectly, its a 1.4 16v lump as seen in the Polo & Fabia etc.
Once the car is started there are zero problems, it drives beautifully.
The car sometimes starts perfectly but is normally when its cold outside or its been left overnight. When warm outside or warm as been driven and left for 30 minutes or so it takes a very long crank to get it to start. If when started I take the key out and try to start it immediately it starts perfectly again.
So to cover off a few questions and things I have already done in my rather large quest to resolve this:
1) The car when started drives perfectly, without fault and MPG is good
2) There are no lights on the dash and no error codes in VAGCOM
3) According to VAGCOM everything is good and working, sensors giving good readings and measuring blocks look good, there are no fault codes
4) Earth points checked and cleaned, under the bonnet by the lights and the two A pillars
5) Car has been fully serviced including new spark plugs, oil and filter
6) New Bosch HT Leads fitted
7) New NGK Ignition Coil fitted
8) New Fuel pump fitted (VDO)
9) New Fuel filter fitted (Mann)
10) New coolant temp sensor fitted (Febi)
11) New MAP sensor fitted
12) New camshaft position sensor fitted
13) TPS checked and adapted
14) Throttle body checked, cleaned and adapted, plus replaced also to check with another unit
15) New Injectors fitted
16) One way valve fitted to fuel pipe leading into the fuel rail to see if there was some form of pressure drop at the rail itself
17) No fuel leaks that I can see from the tank, pipes or engine bay
18) Fuel pipes look all good, no fuel smells, leaks or drips
19) Injector cleaner and fuel cleaner run through the system
20) New Varta Silver battery installed
21) New PCV Oil Separator fitted
22) Pipes and breathing looks good on the car, no obvious vacuum leaks
23) New Oil pressure sensor fitted
24) Spare Key tried in case this was an immobiliser problem
25) New Fuel Pump Relay (612) fitted
26) New front Lamda sensor fitted
27) Battery terminals checked, all good and clean etc
28) Another fuel pump fitted to triple check
29) Another coolant Temp sensor fitted to triple check (Meyle)
30) Full tank, empty tank of petrol makes no difference to the problem
31) Crank position sensor replaced and tachometer does move in start up *EDIT
With all of the above done, whilst making the car run even better made no difference to the starting problem!
If I run the fuel pump for ages before starting with the key in position 2 it does not have any impact on the starting problem. Its been like my little challenge to try and fix but I am running out of ideas here, its like perhaps vapour lock or it needs an Exorcism!
