Old 19th September 2010, 08:05 PM
Default Rubber door selas (outer)
Hello everyone,
Thinking to replace outer rubber seals around window frames and didn't find part number for those rubber elements in ELSA.
Questions:
1. Is it possbile to change them from outside, without removing door trim?
2. Are these seals inseparatable from window guide frames?
Thanks.
Old 19th September 2010, 08:47 PM
Which one do you mean, 11 or 12?
Old 20th September 2010, 11:07 AM
Not 11 and not 12. I meant seals that you can see from the outside of car.
On the picture below the place where this rubber seal starts is highlighted with red (this is not A8, this is just picture from internet :^) These seals go around window frame.
Old 20th September 2010, 12:07 PM
Ok. Those just pull out and push into a sort of double self locking slot. I can't find them in ETKA either!
Try A8 parts.
