I have noticed over the last week that the air-con has stopped being cold , I ran vagcom over it and the control unit is not throwing any errors up, I had a look at the air-con rad just in case something had made its way in ,but this also looks ok.
what I am unsure of is the magnetic clutch supposed to click when the the econ button is turned on then off again ,and is there supposed to be a click from any relays inside the passenger foot-well box ,as I am unable to hear anything when I press, I didn't even hear any clicks when I tried the diagnostic option from vagcom. Any help would be great ,you think it might be anything as simple as a fuse for the clutch relay ? ( that's if it has such a beast ) The last regas was at the A8Parts meet. |
I have also noticed my AC is not too good at the moment, but have noticed if I press the "econ" botton, it does blow cold. I havent bothered to vag-com it, I am thinking of changing my car soon. try play with the buttons, or maybe it needs re-gas
Regas fixes many A/C problems
The R134a refrigerant molecules are much smaller than the older R12 ones, and do leak out of perfectly working systems over time, which is why an A/C service is now fairly essential every 3 years or so. A proper regas will suck out the gas from the system, and refill, adding lubricant too. A report is usually produced showing what came out, and what went in. The different is quite amazing. Running really low on gas gives no cooling, running quite low gives poor cooling, and running a bit low will cool ok, but take more energy and fuel. If you're local, a8parts do offer a regas service at competitive rates ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Had mine re gassed yesterday at ATS, £45. And you're correct Ian. I got a print out of everything that was removed and then replenished, there was a big diference.
My cars interior is now even cooler ![]()
A journey of a thousand+ (epic) miles, begins with a single step, (to the door of an 8). Lau Tzu |
regas was done this year ,so I was hoping it wasn't that
Maybe where you had it done didn't do it properly? Or the system has a leak. I've never had the 8 done and it's probably due time wise but she still blows cold. I have however had the Leon done and the place i use are a refrigeration specialist http://www.keepitcoolsouthwest.co.uk/ they pressurised the system and checked for leaks before re-gassing / lubing the system and then testing it. I know it’s a long way for most people to travel but it might be worth finding a specialist rather than a back street garage, I have friends that have used these and the gas has just leak out after a couple of weeks and then back to square one, sent them to keep it cool and they have fixed it properly ok it cost a touch more but not as much as re-gassing every month.
The 'top of the range' single units are the best to look out for - They do all in one, and it will extract the gas and then run a vacuum test.
It does this to remove moisture initially, but then holds the vacuum to test for leaks for around 10 minutes. It should then (by law) only be refilled if no leaks are detected. Some of the cheaper kit uses one device to extract, one to vacuum, one to fill, and these wont run a comprehensive leak test..... The only time you need a more comprehensive A/C servicing outlet is if there is a leak, or a component is suspected as faulty - Then you're better off speaking to the pros.
As A8parts have a good machine and it was only done a few months ago that is why I was focusing on other possible problems ,I will look n the fuse box first to see if anything is wrong there.
It could be the dryer that's gone.. they do have a finite life, especially if it's ever been exposed to the air. Or given the age of the car, could be the compressor has decided it's had enough.
VCDS would allow you to scan it. If you don't have a copy, happy to plug mine in for you at some point.
