Old 30th August 2022, 08:05 PM
Default It's 1st January 2069!
Got in the S8 today and noticed the clock in the DIS was wrong.
It had the correct minute but the wrong hour (can't recall which, but maybe American PST, a few hours behind anyway).
And the date was 1.1.2069!
I corrected the hour with the menu system in the centre console but that doesn't allow you to change the date.
I should state that I have the radio-controlled clock module added, which has worked fine for several years.
Does anyone know if you CAN adjust the date, if so how?
And has anyone else with the radio-controlled clock add-on seen any oddness lately?
Old 30th August 2022, 08:23 PM
Ronin Ronin is offline
Just unplug the battery
Old 8th September 2022, 05:55 PM
I've got the radio controlled clock and my date disappeared completely from the display, leaving just the time. It happened sometime in the last 2 weeks whilst we were away in Greece. I managed to get it back using the menu and the date was correct. But a quick glance at the menu suggests that you can, indeed, change the date.
Old 8th September 2022, 09:43 PM
Well try the menu, the date option is there but not accessible.
Anyway mine updated so that the date was correct, the minutes too but the hour was wrong, presumably from my previous correction.
I updated the hour and it's all good now. Must have picked up a duff radio signal.
