Dear All,
what could I mean??? Excess of Aero? Or perhaps the moonwalkers chimpanzee???? No, I'm talking about my usual bain, My '8!! Tried unsuccessfully to start it last night, (cold again!!) inserted the key in the ignition, span emgine over, fired, stopped, and then a bubbling noise from the rear.. Could anyone tell me what, if anything might be under the battery?? Possibly getting water logged, maybe vacuum pump for cent locking?? Many thanks Guys'n'Gals Best Regards, Steve |
Hmmmm. I'm now starting to think fuelling issues.
To test that the fuel pump is working, have someone put their head in the boot as you turn the ignition on. They should hear the fuel pump run for a few seconds as it builds pressure. After that there are a series of tests you can run to check that the pump is working properly. I'll see if I can find them. There on one of the forums somewhere.......
Hi Conan,
I'm not sold on that especially, although your suggestion is viable! I can confirm that the pump pressurises the system and switches off when it has done so. I spoke to an auto electrician earlier, it appears that something I neglected to mention was that prior to this prob I DID jump the A8, the auto sparks seems to think I may have in advertently damaged the immob/clock set, and has advised me to get a s/h set, but trying to get hold of A8parts on a saturday is proving difficult.....! (Ian, I believe??) Best regards, Steve |
They bon't open on a Saturday. odes did it have please?
Odes?= Mileage? car has does about 81K, No worries, I'll be on the phone to the main man on Mon am!!!
Many Thanks Conan. Best Regards, Steve |
Sorry I meant codes as in VagCom? Silly spulin on my part.....
18058, I think, missing message from Instrument cluster is the main one, and low volts @ terminal 30, if thats indicative??
Many Thanks, Steve |
Could it be the battery? Have you looked at it as I beleive terminal 30 isthe general +ve supply
Hi PsYcHe,
remotely possible, but was new(Bosch) at last Easter. Also, no probs cranking the motor over, big lights etc, just no continued ignition!! Many Thanks Best Regards, Steve |
From the Ross Tech Wiki
18058/P1650/005712 - Powertrain Data Bus: Missing Message from Instrument Cluster Possible Symptoms
Also possible that the ECU has got wet and a bit of corrosion on one of the pins. a quick strip of the ECU loom plugs would show this.
