Folks
Have noticed that occasionally I get all the gear shift lights coming on with a red background, so you can't tell what you've got engaged without looking at the shifter. Am I right in thinking this is an indication of limp mode? There's no lights on the dash to accompany the DIS going all red on me ![]() Sometimes it's done it when I've just started the car, other times after I've moved off. Generally restarting the car seems to clear it. It did it this evening when I needed to move the car to get the other one out and seemed a bit less keen to react to throttle than normal. Since I'd cold started it I didn't want to cycle the ignition just to prove a point. Under normal driving the shift is extremely smooth with no hesitation when selecting gears, or moving the selector. Where should I start to look to pin down any issues? Could this just be low fluid? I have a friend who can check the fluid level and vag-com the car, but he's not back at work till 4th jan. From past experience with my Passat if I drive to his place I'll have to leave the car sitting for about 4 hours before it's cool enough to do the fluid check, which isn't ideal with an 8 month old in tow..... Adrian |
