Brake pad warning light came on a week ago so decided to change the pads.
Got them this morning from GSF and then set about changing them. Decided that the discs have seen better days so bought a set of these. OK - read all the previous posts about the bolts holding the calipers on and being a bitch to get off, but noticed that the caliper on the outside is held in with a couple of nuts - could I just undo these (they are like larger allen key style nuts - about 12 MM across I think). If I could get this off, then the outside pads will just fall out and I'm sure the brake disk will also come off. Should I do this?? Cheers
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice ![]() |
The disc won't come off with the carrier still surrounding it - you will have to tackle the very difficult carrier bolts!
I quickly realised human strength wouldn't get mine off, so I ended up using a breaker bar with the end touching the ground, then lowered the car so that the car's weight would undo the bolt. |
Big spanner... Big Hammer on the bolts at the back
![]() I assume the D2's similar, but the D3 caliper bolts go on at 190Nm (or big belt with a hammer). Interestingly, the D3 rear disc will come off with the caliper mount still on.
Cheers guys.
Seeming that the pads have plenty of live left in them, I think I will avail myself of my friends garage when he comes back off his hols and use his more manly tools (if you know what I mean).
Can anyone confirm that the carrier bolts are 18mm? Just it's a non standard size and I don't want to tackle it with the wrong socket
I think they are from memory, though maybe 19s. And they usually need a good smack to get them off...
I usually do the bottom one first as it's easy to get to, then knock the caliper carrier a bit to loosen the top one off.
A six sided socket is the best for this as it is less likely to slip and damage the head of the bolt.
. Nite Blue 3.0L SE Quattro |
Thanks guys and I was thinking six sided socket might be best.
Or one of the big spanners from Halfords (not the staff!) to save your ratchet.
