Old 12th February 2012, 05:50 PM
frankow's Avatar
frankow frankow is offline
Default 25mm H+R Track+ Hubcentric wheel spacers
The best wheel spacers for the D2, lightweight magnesium alloy with hubcentric lip.
Fills out the arches perfectly with the standard 20" FE rims.
As new, all bolts, simply bolt these onto your hub and use your existing wheel bolts to attach your wheels to them. The best D2 upgrade by far!
http://www.motorsportworld.co.uk/fra...es.asp?code=34
(Listed as hub pair i.e 50mm, over £100)
£70 delivered within mainland UK.
Old 13th February 2012, 11:18 AM
Zip's Avatar
Zip Zip is offline
Question
Do the rear tyres rub the arches when the back of the car is loaded up?
Seen a lot of guys using 10 or 15mm, but not 25mm, although looks great.
Thanks,
Zip
Old 13th February 2012, 03:51 PM
frankow's Avatar
Post
Thanks,
Zip
No rubbing, no stone chips, no issues at all.
Had them on the car since this post but now I'm afraid the car has gone
http://forum.a8parts.co.uk/showthread.php?t=2050&page=5
