Old 5th March 2012, 06:28 PM
graynada graynada is offline
Default Rough idle on warm start.
When the car is warm, ie the temperature gauge is between the stop and 90C, my car idles really roughly. If I am stationary for more than a couple of minutes then the CAT light flashes. This is noticeable from a cold start and having driven about 3 miles or when the returning to the car after a short stop.
When the car is up to normal temperature it is fine. When it is stone cold it is fine. Under any throttle it is fine.
For this reason I have discounted vacuum leaks, dodgy MAF as I guess these would not be so temperature dependent. When pull the codes it is always both lambda sensors showing no activity and random misfires; however I suspect this is symptom rather than the cause.
Can anyone give me any pointers where to start?
From previous marque engines I have worked on I would be thinking of cleaning the Idle Air Control Valve. How does this engine (ABZ) control air flow at idle?
Thanks in advance
