just got my iphone and want to connect it to my car but no idea
![]() my car is a 53 reg D3 but doesn't have a built in phone or bluetooth by the look of it ![]() saw 1 item on the interweb but was a module costing £300 ! must a cheaper way ? |
Erm.. not really. The only options are either a 3rd party kit which is a bit of a bodge, or the Audi kit. But this is just for phone. You then would need AMI for music from it.
Mmmm.....thats a bugger.
whats the AMI crack then for the music part of it ? how much ? big job ? |
right sorry about my ignorance in the previous reply !
done a bit of research on the AMI aspect of things and it aint lookin cheap.....until.... i found this http://cgi.ebay.co.uk/Audi-Ipod-Inte...item2a07612d2c does anyone know know if this is the right part number etc for a 2004 D3 ???? seems awfully cheap considering these units usually go for around £250+. too good to be true ? |
That looks like the fella.. You'd need the cable for the ipod/HDD which is about £30 or so.
Looks like it's the kit for going alongside the CD Changer. I just swapped mine over as it's really easy.
Cheapest way is with a tv tuner.
On av 1 input use a phono to stereo cable and run from front to back. |
check out Zenec head units, I understand the DIS works and can connect to yhe i-phone.
http://caraudiosecurity.com/shop/pro..._id/12332.html |
Sorry to revive an old thread but if antone's interested, I fitted a mobridge unit to my D3 when I bought an iphone - provides a cable for charging (still need to route that into the armrest) which also allows you to use it through the MMI as another CD changer. Phone is through bluetooth - just need to run a new MIC cable up to the mirror area - 10 minute job. The mobridge unit replaces the built in 'phone module under the seat - no codng required.
![]() 2005 A8L W12 Almond Beige 2008 Jaguar XK Convertible 1971 Jensen Interceptor II (soon to be Mendip Blue) |
Thanks
A8 4.2 S
http://www.caraudioexpress.co.uk/aud...i-systems.html
Though, for a similar (or smaller) amount, you could get an AMI and Audi Bluetooth kit too.
