Old 30th July 2012, 12:59 PM
RanjS8 RanjS8 is offline
Default How does the head come off an AVP engine
In my quest to repair this engine, I ve got to the point where I have undone the head bolts and the only thing attached to it is the exhaust manifold....
Do I have to take the exhaust manifold off as well or should it peel off with a tug....I have tried hitting it gently with a rubber mallet and the damn thing wont budge....any suggestions or advice would be appreciated...
Thanks
Ranj
Old 30th July 2012, 01:25 PM
The head is dowelled so you need to free it with vertical force rather than trying to slide it
Are you aware there's a correct sequence for removing head bolts?
Old 30th July 2012, 04:11 PM
Default Sequence for removing bolts
Yes I have the instructions from elsa win...so I removed the bolts in the correct sequence....not sure why though...as the head isnt moving at all....
I ll try pulling up in vertical motion...
Old 30th July 2012, 04:25 PM
Or you need a bigger hammer
Old 30th July 2012, 04:47 PM
Breaking the joint can be a PITA on any engine - it went together a long time ago and been heat soaked plenty of times! Wouldn't surprise me if it needs a good smack to free it off....
Old 30th July 2012, 06:43 PM
Default sealled tight
the valve cover is fairly tightly sealed and needs a couple of whacks to freak....but the head itself I kinda scared of hitting too hard...
I think there must be vacuum seal there and I want to put a flat screwdriver in to break the seal I dont want to damage the joining seals.
Old 30th July 2012, 08:12 PM
plugs out?
Old 30th July 2012, 09:38 PM
Default Plugs
I m sure I took them out already...however for the sake of sanity i will check...
my next step will be my trusty rubber mallet...time to give it some hell after all the trouble it has caused me!!!!!!!!!!
Old 31st July 2012, 09:07 AM
Default The head is off.....good swift hit with a hammer it came off
Well the head is off.....
Now I m in the world of the unknown...can someone tell me if this piston looks ok....the bore wall looks nice n shiny like the other bores.
There are a couple of small scratches at the top but surely that cant do anything bad can it???
Old 31st July 2012, 10:32 AM
Reffro Reffro is offline
Is it just the the camera angle or is there a bloody great chunk of the piston gone in that photo?
