Old 3rd September 2012, 08:54 PM
Mutley Mutley is offline
Default Background Lighting
Anybody come across this ?
In the MMI i have the option but all the needles regardless of option are on the lowest, when i turn the nob the needle flicks up and jumps back, i thought it might be MMI update but still the same ?
Its a 2003 but as it was on the MMI which had never been upgraded before i got it i assumed it should work ????
2003 Audi A8 D3 4E, 102K Miles, 20" Alloys, 4.2 Quattro
Fixes i've resolved myself and with the help of the forum and Vagcom
  • Update MMI to 5570
    Hidden Menu
    Brake Switch Repair and ESP Light
    Reset Parking Brake Calibration
    Removed Speed Limiter
    TV In Motion
    Reset and resolved issue with Cruise Control
    Coming Home Lights
    Lowered 10mm
    MMI Replacement brass gear for silky smooth action
Old 3rd September 2012, 09:22 PM
Depends if you have the lighting pack I think. Do the door panels light up?
Old 3rd September 2012, 09:38 PM
Not sure what I should be looking for to answer that but all the doors have a white and red light on them ?
    Hidden Menu
    TV In Motion
    Coming Home Lights
    Lowered 10mm
Old 3rd September 2012, 10:19 PM
there's a 'strip' along the top of the little panel above the handle shines down the way
Old 3rd September 2012, 10:21 PM
Don't have that , guess that's that then - shame the options there
    Hidden Menu
    TV In Motion
    Coming Home Lights
    Lowered 10mm
Old 3rd September 2012, 10:27 PM
Probably appeared from the MMI update as a result of a default coding.
