Old 13th November 2012, 07:03 PM
oldnick oldnick is offline
Default E10 95 grade petrol in france
my local garage here in france has stopped selling 98 octane petrol , and now has a choice of 95 octane or 95E10 [ 10% alcohol ]
did a bit of googling about audi engines , and with a couple of exceptions anything since 1985 should run correctly on this
so tried some in my 5cyl 20v , ran ok but after a few days not used it was almost impossible to start ; once warmed up seemed ok , left a few more days ...same problem ...ran battery flat , had to recharge before it finally got going
question is , what about my 3.7 A8 ...has anyone tried this particular fuel ?
it is about 10% cheaper than pure petrol here
Old 13th November 2012, 07:36 PM
Amanda Amanda is offline
An E.U directive IIRC insists that petrol has a % (up to 10%) of ethynol in and as far as I am aware no petrol Audis are designed to run on it.
http://www.e-energymarket.com/news/s...containin.html
Old 13th November 2012, 09:01 PM
in that case why does the list in the link you provide show that 99% of audi's since 1992 are ok on E10 ?
Old 13th November 2012, 09:11 PM
Reading between the lines on the manual for my S8 when I first got it, it implied that it would run on pretty much anything except diesel albeit with "reduced" performance.
I think the worst I've put in it was about 89 octane and it was fine.
The ethanol thing is mostly about seals etc. that may fail when exposed to the mixture.
