Old 6th June 2010, 02:10 PM
Default 01119 - Gear Recognition Signal (Intermittent) in ABS
Hi guys, did anyone experince this error code in ABS?
Frankly i don't even understand meaning of the message, as word gear can mean two things
Does it mean ABS cannot talk to tranny or does it mean ABS have problem communicating it's own "gear", i.e. ABS sensors?
ELSA suggests this error appears in ABS when Transmission control unit throws an error.
But my transmission have no error codes in it and works very well.
This is strange.
Below is VAGCOM output. Apart from this ABS error there are no more errors in the vehicle and no warning lamps on instruments panel.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D57
Coding: 08397
Shop #: WSC 02313
1 Fault Found:
35-10 - - - Intermittent
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4D0 927 156 DT
Component: AG5 01V 3.7l5V RdW 1920
Coding: 00001
Shop #: WSC 02313
No fault code found.
I saw a number of posts in different audi forums in US, UK, Germany and Russia from people with exactly the same situation, but I didn't find any definitive solution of what can it be...
