Having had several A8s I now have a 4.2 TDI, which I find disappointingly slow. According to the claimed figures this car will do 0-60 in 5.7 secs. Mine, however, will do it in 7.0 and cannot get below that.
I can find nothing wrong with the car--no fault codes or obvious problems anywhere. The worst I could say is that the gearchange is a little slow--almost as if it bogs down slightly before changing up on acceleration, but I put this down to a typical kind of diesel experience. It's certainly not as Evo Magazine described it in their review: 'Gearchanges glide through the six-speed Tiptronic automatic with a barely perceptible change in engine note, and without any interruption to the remorseless surge of thrust. And suddenly you've wafted into the 155mph speed limiter...' Is it just the case that the real world performance of these cars is not as claimed or should I be looking for a problem somewhere? Any advice or experience would be appreciated. Last edited by sutherland; 1st April 2013 at 12:22 PM. |
Normally people are saying these are really quick...so I m surprised you are saying it is slow. I would get it put on dyno and see what kind of power it is putting out.....also it might be worth while having a look for any obvious boost leaks.
Finally....I wonder if these have a dpf or if the mileage is low and causing carbon build up?....in short I agree I would be expecting far better from a 4.2tdi.
01 Audi a8 fl sport - Grey, Bose, Glass Sunroof, S8 grill/mirror covers/wheels, Aftermarket Exhaust, very quick and lots of fun!!!!!....well I gave it one final push on the pedal to hear that v8 growl and then it was off to a new home..... 99 Audi a8 fl - Silver, Black alcantara seat/ S8 grill/side mirror, MFSW, Solar Sunroof, 17" Monoblocks (for that extra cushion of air), Rnsc, Bose.....great motorway cruiser....now gone to a new home 02 Final Edition S8 - Avus Silver, Extended Leather Pack III, Front & Rear Heated Seats, Servo, Blinds, Rear Seat Entairtainment with Playstation, Bose, Bi Xenons.....now gone to a new home 97 PF A8 4.2 quattro sport - Cashmere Grey, Servo, RNS E, Blinds, Bose, 20 Final Edition Alloys, LPG....sold sadly and will be missed 03 S4 V8 Saloon - Misano red, Manual, Milltek, Bose, Xenons, RNS E - Sold as of Feb 2012 |
I do notice a little pause on the gearchange, and whilst I've never times the 0-60, it's definitely quick.
Thanks for the responses.
The mileage isn't that low and I believe they do have a DPF. I could certainly have a look for obvious leaks, but wouldn't that cause a check engine light? I'd be interested to know what 0-60 times other owners get in real life. I checked it via OBD on several runs, so I think it's fairly accurate. |
I've had a development with the CEL coming on and the following fault code:
004204 - Throttle Valve 2 P106C - 001 - Stuck or difficult to move - Intermittent I guess this could be behind my poor performance, but I'm not sure what the solution is. I didn't think the 4.2TDI had the intake manifold problems common to the 4.0 or that they had the throttle body problems common to the 3.0. I'd imagine if the valve was really stuck that I'd know all about it. Normally sticking such a fault code into Google brings up a whole lot of stuff, but this one only brings up a post in Finnish about from a 4.2 TDI owner with the same problem, which he seemed to think was somehow related to DPF regeneration. There are plenty posts concerning 004203 / P106B, which I assume is the same problem on cars with one intake manifold, so I might work out a solution from that. Last edited by sutherland; 2nd April 2013 at 04:11 PM. |
Hi,
My 4.2tdi is pretty quick. It pulls in all gears and it shifts smoothly through the gears. I had an e60 m5 before the a8 and performance Wise, the a8 doesn't feel that far behind it. Paul. |
Hi Paul,
It does seem as if my car may be a bit sluggish. My first priority is to sort out the throttle body. I took it off and cleaned it today. It was fairly gungy and I got it moving more easily, but it does not close completely and is stuck about 20-30 degrees open. I'm not sure what could be causing this and I'm reluctant to force it. I may try removing the plastic cover and seeing if there is anything obvious amiss in there--perhaps they used the same feeble plastic gears as they use in the MMI display. Does anyone know how to do the throttle body adaptation in VCDS? The usual procedures as outlined by Ross-Tech seem to assume only one throttle and the channels they mention are not the same on the 4.2TDi. Thanks Philip |
I eventually got my throttle body replaced and a DPF regen, which improved performance and stopped a wailing noise caused by back pressure. However, I still think the performance is not what it should be--at least it's a long way from published figures. I get the following best figures:
0-60: 6.7s 1/4mL 16.1s 99mph Does anyone else out there have an Torque Scan running on their Android phone? If so, and you've got a 4.2 TDI, I'd be interested to know what figures you get for your car using the realtime information. Perhaps the claimed figures of 5.7 secs are actually miles away from the real world. |
Mine doesnt hang around either. I'm more used to it now, and once north of 30mph I'm convinced it would give a W12 a run for its money. Its certainly a lot quicker than the 3.0 Tdi, or the 4.2 petrol.
My gearchange in 'Drive' is sluggish to say the least, and round town often feels like its bogged itself down in the lower rev range with the turbos offline, but in sports, or manual, or just at a cruising speed, its very hard for it *not* to be picking up speed rather quickly ![]() For a daily driver, it really does seem to be the engine of choice. Yes, the W12 or V10 will sound/perform nicer - but - using twice the fuel, and thats a staggeringly huge cost for some audio pleasantries and 0-30 elitism...... ![]() I know it doesnt help at all, but the 4.2 Tdi in the wifes Q7 feels *even* quicker, although I'm sure its a gear ratio thing, but for a 2 ton+ barge my god that thing shifts. ![]() ![]() Im Apple, not Andoid, but happy to do some tests on my motor if it helps..... ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Thanks.
Don't go to any trouble with the tests, but if you happen to have a way of measuring performance figures via the OBD port, I'd be interested to know the results. The car goes fine, so perhaps it doesn't matter, but if my 4.2TDi is 1 sec slower to 60mph than every other car, it would be nice to find out why. |
