got abit of a problem with my 2.8 my oil light coming on only so much of the silly buzzer sound i can take
![]() the light will come on when i have done about 10 miles with out fail even if the car has been running for about 15 mins on the morning its -8 to +1 here on the morning. i can even just jump in it on the morning and it will still can on more or less at the same point i have seen this is a common problem when looking even with the 2.8 passat but no one says how there sorted it only some people put high pressure oil in ![]() i have did the following oil level is on the max changed the oil pressure sensor cleaned oil pump out was full of bits and sump pump been checked all ok fitted new pump got it cheap off a mate thinking old one may have been temperamental new oil and filter 5w-30 fully syn put some engine flush oil through it |
You need to check oil pressure with mechanical gauge to see if is low or if it's just reporting low pressure. Do 2.8's have oil level sensor as well or just pressure sensor?
Edit: Had a quick look, 1998 2.8 30V ACK engine does not have oil level sensor, just pressure switch and oil temperature sender but oil temperature is not used in A8 so it's only pressure that is reported to dash. And i'ts a simple pressure switch. If pressure above 1.4 BAR it's closed circuit, if pressure below 1.4BAR - it's open circuit. So if you have oil light on there are several possibilities: 1. Low oil pressure 2. Faulty pressure switch 3. Wiring fault between switch and instrument panel 4. Faulty instrument panel
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 29th March 2013 at 11:04 AM. |
As he said above - you must get an actual gauge on it.
I would add that fully synthetic can be a bit OTT for an old engine - I don't know the miles or use etc. The Oil Light switch is only to alert for low pressure not level/volume. As you took a load of rubbish out the old pump it looks like some damage has occurred to bearings so clearances are bigger so pressure is reduced and so on. Brace yourself for bad news ![]() |
pressure is good can not remember what the pressure was left paper at mates garage sludge is normal is the 2.8 engines from what i have found engine has 110k on it |
have found loads of posts when looking on the net about sludge been a problem
and it has a full service history by audi |
