Old 23rd December 2012, 02:44 PM
Lightbulb W12 Lambda sensor Replacement Guide
Well my Bank 1 sensor 1 on the W12 failed and caused the cell to come on emmissions below threshold ect so i changed the sensor and it took me all of about 10 mins to do so hears how i did it.
first off remove the maf sensor followed by the air box it should look like this by now ...
Next i used a pair of plumbers grips to loosen off the sensor .. then unclip it and remove .. like this
and then the new sensor
now reverse the procedure ... and bingo .. no more cell light and better mpg again
hope its help full to people who are scared of tackeling the W12 themselves .... its not such a scary beast
Old 24th December 2012, 12:16 PM
Added to repair sticky
Old 28th December 2012, 12:27 PM
A8 Doc A8 Doc is offline
Blimey that was far too easy.... Sure the A8 4.2 is harder than that!
How's the codes now Guy?
Old 11th January 2013, 04:50 PM
carterleeds carterleeds is offline
can i do this for my 4.2 v8 d3?
Old 21st February 2013, 10:14 AM
GlynH GlynH is offline
Interesting discovery & solution db
I had heard it could be as much as £3k to change a Lambda probe on a W12 (depending upon which one it was that had failed) as it was an engine out job...scary indeed!
Can I ask how you identified which of the 8 probes(!) it was that had failed and what fault code was reported by VCDS?
Thanks & kind regards,
-=Glyn=-
Old 21st February 2013, 01:09 PM
well it was plugged into vag com and it stated bank 1 sensor 1 . but you can actually get to all 4 under the bonnet of course you have to take the air boxes out ect and to get at the rear ones its a bit tight but if you take the intake manifold off you can get at them both fairly easy.. engine out would be 4 new cats as you cant take the manifold off without the engine out i guess. but lambdas easy peezy
P2251
P0135
thats the codes i had
