Old 7th May 2013, 07:57 PM
Default V5 in an A4?
Didnt think they did the V5 in the A4 did they? suspect he might be confusing the fact it says 5v on the engine, thinking this might be a reasonable daily driver, any advice on what I should look for on these, bearing in mind that the price is less than what attending the annual meet will cost me
http://www.gumtree.com/p/cars-vans-m...-v5/1017772972
EDIT
must have been OK its gone already
Old 7th May 2013, 08:42 PM
And yep.. the 1.8 was 5v.
Old 30th May 2013, 05:24 PM
S4_Sat S4_Sat is offline
5v is 5 valves per cylinder, V5 is 5 cylinders.
Old 30th May 2013, 05:55 PM
Except Audi only do a in-line 5, not a V5, nobody does as far as I know!
5V is 5V per cylinder as Sat says.
Old 30th May 2013, 05:57 PM
Usual stuff:
If auto avoid front wheel drive multitronic - it's dreadful and unreliable. Really old A4s will still be proper autos
5v suffers oil pickup issues, particularly turbo cars. Needs the sump dropping and pickup cleaning every few years. If oil changes neglected turbo oil seals get knackered. They ALL like a drink of oil
Fuel economy on our 1.8t auto passat was no better than our 3.0 v6 around town
Cheap front suspension joints failing
If you don't need all the space consider a Seat as well - decent steer the Leon and Cordoba
Old 30th May 2013, 09:04 PM
VW used to do a V5 engine, fitted to Golfs and Boras... Not a 'true' V5, but was marketed as such on the badges.
Old 31st May 2013, 01:25 AM
It was VR5, like VR6.
