Old 17th July 2013, 01:57 PM
Default Jack of Death Pt 94
Thought I would remove front offside wheel to clean it as I had cleaned/waxed t'other when sorting the ABS sensor. (30min job at lunchtime so I thought). Well it was until, without any undue force exerted, the jack folded up and the car dropped onto the (new) disc. Fortunately I had no part of my body under the car so escaped lightly. The drive is fairly level with the slope towards the nearside. Car was in Park and brake was on. Now I know why it is referred to as the "Jack of Death". What a design! It took some long levers and a trolley jack to get it sorted out. Need to go and test the hub/disc/caliper assembly now - carefully - to see if anything is out of alignment.
Name:	Jack Failure 001.jpg
ID:	6396   Click image for larger version
Name:	Jack Failure 002.jpg
ID:	6397   Click image for larger version
Name:	Jack Failure 003.jpg
ID:	6398   Click image for larger version
Name:	Jack Failure 004.jpg
