As per my other thread, my D3 is suffering from two faults. One maybe related to a slowly dying compressor but the other one.
01400 - Suspension Level Control 002 - Lower Limit Exceeded - Intermittent Could this be due to a faulty or otherwise problematic issue with one of the level sensors. I have not been outside to check as its raining and has been all day, and now its dark as well. Earlier on after the warning lights popped up on the dash again, I switched off and restarted. No faults in more than 10 mins of idling, so I started adjusting the suspension settings in the car menu. Car was raising and lowering fine, perhaps slower than it should due to the potentially dying compressor. I moved the car to level ground, and I am sure I returned the car to the automatic position before switching off the ignition. From the lounge it looks like the left front wheel has a larger gap than I would expect. The rear looks like it does in the picture below this post, but the front has a larger gap than this picture. After I drove the car yesterday, all four wheels were looking fine. Before yesterday, no issues at all. it also drove fine after restarting yesterday. Now the house I live in is accessed via a typical compacted mud/stone farm track (200 yards of it), and it is has a number of large pot holes in it. I always drive slowly over them, but there are a couple of big ones. Could something to do with driving over these holes disturbed the level sensor as the supension will be articulating more than on a flat road. I know the compressor is heading in the poorly direction, I know there are no leaks in the system as the car will hold the height its left at with no signs of sagging. I wonder if the issue with the suspension is perhaps due to a faulty level sensor, but how can I check?. I can check the electrical connection, but apart from swapping a possible suspect one out what else is there?
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 5th January 2014 at 08:02 PM. |
