Old 2nd April 2014, 11:28 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Central Locking Went mental
Went out to the car to, unlocked with my hand under the passenger door handle, opened the door and sat in.
Got in did what I had to do and left.
With the key still in my pocket I pressed the button on the door handle to lock the car and it started locking, unlocking, it did this for about 10 seconds.
It stopped, I opened the door, shut it again and it went mental again.
I took the key out and pressed the lock button, nothing happened, still going mental.
Pressed the unlock button and same thing.
I walked around to the drivers side and it stopped. I tried locking it with the key and nothing happened.
It would not lock or unlock and the LEDs was not on. The doors was opened, so I get in, started the car, waiting a bit and got out. Locked it with the key and left.
All very odd.
I have a fault code for the passenger door handle switch not working, so I wonder if its the switch breaking down even more or it might be the wet squelching noise it made when I pressed the button.
If the weather is dry I'll do a VCDS scan.
Anyone else experienced this?
[center]
06 3.0TDI Quattro:
Options:
