Old 23rd December 2013, 06:23 AM
mannyo mannyo is offline
Default 3.7 D3 exhaust flexi joint
I bought my D3 knowing that the exhaust had a slight leak.
On Saturday, I paid a visit to the local workshop I have been using for years. They put the car up on ramps, and I was finally able to get underneath the newly purchased D3.
The part with the hole in it, is the nearside flexi joint. The outer mesh is undamaged, so the hole is internal, and from what I could see the flexi is post cat and lambda probes.
Now all I need to do is source a replacement flexi repair part, have the old factory one cut out and new inserted. I'll proberbly end up with a clamped in solution, rather than welded as that will save a lot on labour as it can be done in situ.
Manny
Past
