Old 7th October 2014, 03:10 PM
BADES's Avatar
BADES BADES is offline
Default Refurb 19's the right way
Hi All,
I've got 19" BBS which have been sprayed up (previous owner) but I think they look a bit.... Hmmmmm
I found a pic of a wheel finish I really like - can anyone tell me anything about the finish and the bolts etc
Ta.
ID:	9197   Click image for larger version
Name:	genuine_19_audi_a8_bbs_rs865_2_piece_split_rim_alloy_wheels_5x112_a4_a6_vw_passat_golf_gti_mk6_5.jpg
Old 7th October 2014, 03:58 PM
BADES's Avatar
I have to replace the tyres soon - so I thought I might get a slightly bigger tyre wall for comfort... (I'm not much of a racer anymore)
currently 255 40 r19 - might go for 255 45 r19
has anyone tried this/do you think it will cause any problems ?
(I understand about the speedo being a little out)
Ta
Old 7th October 2014, 05:18 PM
It won't cause any problems on a D3 - there's loads of room. As long as you do all wheels and any spare at the same time then it will be fine and as you suggest just slightly throw the speedo out a tad.
Old 7th October 2014, 05:32 PM
They are 3.64% bigger, so the speedo will read LOWER by that ratio, about 2mph at 70.
Most speedos (dunno about a D3 though) overread by up to 10%, though that will depend to a slight extent on the level of tyre wear. I believe showing a speed lower than actual road speed isn't legal.
Old 7th October 2014, 06:37 PM
sarg sarg is offline
It's the other way round HP, speedo showing a speed too low is definitely illegal, showing the speed too high is not - you wouldn't want your speedo to be showing 50mph if you were actually doing 60mph through an average speed camera section would you?
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 7th October 2014, 06:42 PM
BADES's Avatar
Can anyone confirm whether its true about the 10% over-reading ?
Phantom Schwarz D3 2006 3.0 TDi remapped
Valcona Black Leather, Bose, 19" BBS, VCDS Lowered, Xenons, Bluetooth and still lots to do...
Blue 2007 Audi Q7 3.0 TDi S-line
Heated Seats, Leather/Alcantera, Auto Boot, Sat Nav (NOT WORKING !), Bluetooth, 20" alloys.
Old 7th October 2014, 07:29 PM
Nobody can confirm as it varies from car to car, the only way to test accurately is to check your speed is on decent handheld sat nav or other similar device
Old 7th October 2014, 07:31 PM
BADES's Avatar
Cheers Sarg. I've got a 'little' time before I have to replace the tyres...
I might go on a fact finding mission to test my speedo ;O)
Old 7th October 2014, 07:56 PM
That's what I said. Have a re-read......
Old 7th October 2014, 08:31 PM
sorry, you're right, where you wrote 'legal', my eyes saw 'illegal'
