Hello All
Just putting my 2007 4.2tdi on the road, it was a damaged repairable , repaired the body damage last saturday and it went to VOSA for its VIC check on Tuesday , the car has started fine since i got it , it hasnt done many miles as i cant tax it until VIC marker is removed , however my Dad took it to the VIC check for me , started in the morning no problem ,drove about 5 miles to VOSA and parked up , booked in and then was told to move car into garage. He said it took a couple more turnovers that usual then started up and everything was fine, VOSA checked the car and then come to start it and the car would just turnover with no sign of life. Had to get it recovered back home , initial investigation i found that the battery was only 77ah and was rubbish , im hoping its just the battery . i dont think it was coded to the car as its been sitting a while before i got it and i think someone has just thrown a battery in to get it going. If it isnt the battery does any one have any ideas , i believe that the crank position sensor can go and that would cause similar issues of the engine just turning over with no life. I scanned it last night but under engine in vcds but the only code found was check abs controller or something along those lines. I will be coding a new battery on and rescanning it this afternoon so any ideas would be greatly appreciated as i havnt even drove it on the road yet !!!! Could someone post the location of the crank position sensor from ETKA as i have found etka online but the 4.2tdi isnt included????? Thanks in advance PWACKA8
2012 4.2TDI SE EXEC |
When you replace the battery the car is going to end up littered with fault codes. Replace battery and code it, then scan for faults and clear them all. Now try and start the car, if it does not start scan for faults again.
Hello Manny
Thanks for your reply I fitted a new Bosch s5 110ah Battery tonight and then coded the battery ,once complete i cleared all the codes and then got out locked it and then unlocked and tried to start it , no joy , just kept spinning over , didnt even splutter. Then read codes again CDS Version: Release 12.12.0 Data version: 20130910 Thursday,04,December,2014,15:36:47:62939 Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 11 31 15 16 17 18 19 1E 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 67 6C 72 76 77 VIN: WAUZZZ4E77N016939 Mileage: 143620km/89241miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Malfunction 0010 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 B HW: 4E1 907 409 A Component: 4.2L V8TDI G000AGMª0010 Revision: --H04--- Serial number: AUX3Z0G0315682 Coding: 0011773 Shop #: WSC 02313 785 00200 VCID: 23450907E2202306A91-8076 1 Fault Found: 005715 - Please check DTC Memory of ABS Controller P1653 - 002 - Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 7 Reset counter: 255 Mileage: 143628 km Time Indication: 0 Date: 2013.04.04 Time: 22:35:42 Freeze Frame: RPM: 0 /min Torque: 3.9 Nm Speed: 0.0 km/h Duty Cycle: 0.4 % Voltage: 11.55 V Bin. Bits: 00101000 Torque: 468.0 Nm Readiness: 0 0 0 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 S HW: 09E 927 156 B Component: AG6 09E 4,2 TDI RdW 0010 Revision: --H01--- Serial number: 0101837 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 3365F94752C0B386591-8066 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H46 0510 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 224B0C03FD3A2A0EA27-8077 2 Faults Found: 00532 - Supply Voltage B+ 000 - - - Intermittent 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0G0315682 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: D8BFEEEB6BE630DE0C3-808D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Cannot be reached ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 A HW: 4E0 035 729 A Component: Interfacebox H43 3450 Revision: 00000000 Serial number: 300BS077578755 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 2A5BE423850AF24EEA7-807F Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000031417 Subsystem 3 - Serial number: 0116.02.070000000100010022ÿ Subsystem 4 - Serial number: 010022ÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000114701 Coding: 0022529 Shop #: WSC 02311 785 00200 VCID: 1C3732FBDF5E1CFE68B-8049 5 Faults Found: 00458 - Control Module for Battery Monitoring (J367) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 254 Mileage: 184232 km Time Indication: 0 Date: 2013.01.21 Time: 00:02:37 Freeze Frame: ON Bin. Bits: 00011111 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 1 Mileage: 184232 km Time Indication: 0 Date: 2013.01.23 Time: 01:30:27 Freeze Frame: ON 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 1 Mileage: 143600 km Time Indication: 0 Date: 2013.01.28 Time: 00:16:45 Freeze Frame: Voltage: 8.60 V 01308 - Control Module for Roof Electronics (J528) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 2 Mileage: 143600 km Time Indication: 0 Date: 2013.01.28 Time: 00:00:31 Freeze Frame: Bin. Bits: 00001111 01206 - Signal for Duration of Ignition Off Time 014 - Defective Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 2 Mileage: 143600 km Time Indication: 0 Date: 2013.01.28 Time: 00:00:31 ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 HW: 4E0 035 785 Component: SG ext.Player H09 0170 Revision: 00000000 VCID: E5C1D71FEC949D36875-80B0 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 4 Reset counter: 9 Mileage: 143600 km Time Indication: 0 Date: 2013.01.28 Time: 00:00:28 ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E1 910 409 B HW: 4E1 907 409 A Component: 4.2L V8TDI G000AGSª0010 Revision: --H04--- Serial number: AUX3Z0G0315682 Coding: 0011773 Shop #: WSC 02313 785 00200 VCID: 23450907E2202306A91-8076 1 Fault Found: 006217 - Please check DTC Memory of Transmission Controller P1849 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 11 Reset counter: 255 Mileage: 143600 km Time Indication: 0 Date: 2013.03.12 Time: 00:29:33 Freeze Frame: RPM: 84 /min Torque: 27.3 Nm Speed: 0.0 km/h (no units): 0.0 Voltage: 6.61 V Torque: 795.6 Nm Bin. Bits: 11000000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H14 4210 Revision: 91H14421 Serial number: 0037P0G07NUP Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 275D1D179618CF26F59-8072 Subsystem 1 - Serial number: 63328RB40219F787R Subsystem 2 - Serial number: 63428RB40219F21AJ Subsystem 3 - Serial number: 63528RB40219F2D1N Subsystem 4 - Serial number: 63628RB40219F211C Subsystem 5 - Serial number: 63729RB40206046CD Subsystem 6 - Serial number: 63829RB40206046BD 5 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 0 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 39 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 01316 - ABS Control Module 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 8 Reset counter: 1 Mileage: 184232 km Time Indication: 0 Date: 2013.01.21 Time: 23:28:21 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 46 Reset counter: 8 Mileage: 143600 km Time Indication: 0 Date: 2013.01.25 Time: 00:02:30 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H14 0040 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: E5C1D71F2C949D36875-80B0 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 3 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 6 Fault Frequency: 57 Reset counter: 8 Time Indication: 0 Date: 2063.15.31 Time: 31:63:18 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 3 Reset counter: 8 Time Indication: 0 Date: 2063.15.31 Time: 31:63:02 02072 - Control Module for Energy Management (J644) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 8 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 951 B HW: 4E0 920 951 B Component: KOMBIINSTR. VDO H82 0530 Revision: D04 Serial number: AUDID3G1000959 Coding: 0000413 Shop #: WSC 00414 210 91518 VCID: 24470A1BE72E243ED0B-8071 3 Faults Found: 00562 - Sensor for Oil Level/Temperature (G266) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 8 Mileage: 143600 km Time Indication: 0 Date: 2013.03.12 Time: 00:16:51 00562 - Sensor for Oil Level/Temperature (G266) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 4 Reset counter: 8 Mileage: 143600 km Time Indication: 0 Date: 2013.03.12 Time: 00:16:51 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 9 Mileage: 143628 km Time Indication: 0 Date: 2013.04.04 Time: 00:03:05 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 G Component: Heizgeraet H08 0140 Revision: 0000000C Serial number: 00000009013887 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3B34E3D56A62CE7A7-804F 4 Faults Found: 02072 - Control Module for Energy Management (J644) 004 - No Signal/Communication - Intermittent 00664 - Fuel gauge 002 - Lower Limit Exceeded - Intermittent 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent 01407 - Flame Extinguished 000 - - ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.lbl Part No SW: 4L0 910 468 HW: 4L0 907 468 Component: J533__Gateway H06 0040 Revision: 00H06000 Serial number: 0900B0712581DF Coding: F5D9DFFF70720E Shop #: WSC 02313 785 00200 VCID: ECD7A23BCF7EAC7ED8B-80B9 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Cannot be reached ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2A5BE423850AF24EEA7-807F 1 Fault Found: 01437 - Control Position not Learned 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 11100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 224 Mileage: 143628 km Time Indication: 0 Date: 2013.04.04 Time: 00:15:34 ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 C HW: 4E0 907 289 C Component: Komfortgeraet H09 0020 Revision: 00200009 Serial number: W040702150086 Coding: 0004317 Shop #: WSC 02313 785 00200 VCID: 29591B2F800CF956E3D-807C Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H05 0020 No fault code found. ------------------------------------------------------------------------------- Time: 00:15:40 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000105411 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E3338F3C9420EEE86F-804B 2 Faults Found: 02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 224 Mileage: 143628 km Time Indication: 0 Date: 2013.04.04 Time: 00:20:00 02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 224 Mileage: 143628 km Time Indication: 0 Date: 2013.04.04 Time: 00:16:00 ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 F Component: Dynamische LWR H02 0010 Revision: 00000001 Serial number: Coding: 0000006 Shop #: WSC 02313 785 00200 VCID: 3D71DF7F648475F6BF5-8068 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S Component: TUNER EU/US/RDW H42 0620 Revision: 00000000 Serial number: 396BY077560494 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2E53E833B9E29E6E36F-807B No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000001232 Shop #: WSC 00353 210 91471 VCID: 204F060BF336381EB43-8075 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 0092S50150 Coding: 344530393135313035412056413030303932533530313530 Shop #: WSC 12345 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: Türsteuer.HL BRM005 0180 Coding: 0028462 Shop #: WSC 02313 785 00200 VCID: 1E3338F3C9420EEE86F-804B No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000702050031 Shop #: WSC 12336 024 394758 VCID: 3663C05341B2A6AE7EF-8063 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb Part No SW: 4E0 910 441 HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J72106G Coding: 1020302 Shop #: WSC 02313 785 00200 VCID: DCB7F2FB1FDEDCFE28B-8089 5 Faults Found: 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 0 Mileage: 184232 km Time Indication: 0 Date: 2013.01.21 Time: 00:01:28 Freeze Frame: Term 15 On Reverse OFF Count: 3 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 76 Reset counter: 9 Mileage: 143600 km Time Indication: 0 Date: 2013.01.25 Time: 00:02:15 Freeze Frame: Term 15 On Reverse OFF Count: 3 02203 - Audio / Video Input 1 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 4 Mileage: 143600 km Time Indication: 0 Date: 2013.03.22 Time: 19:46:44 Freeze Frame: Term 15 On Reverse OFF Count: 3 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 3 Reset counter: 9 Mileage: 0 km Time Indication: 0 Date: 2013.01.28 Time: 00:00:34 Freeze Frame: Term 15 Off Reverse OFF Count: 3 00778 - Steering Angle Sensor (G85) 013 - Check DTC Memory Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 0 Mileage: 184232 km Time Indication: 0 Date: 2013.01.21 Time: 00:01:28 Freeze Frame: Term 15 On Reverse OFF Count: 3 Can any one spot anything?????? My missus is getting a bit cheased off with me know as with 4 young kids shes not happy with me taking her car to work and now the car has passed the VIC check i can tax it if i can get it to the MOT station so i can actually drive it!!!! My plan was to be using the car by now and posting a thread with my progress getting it all sorted , not trying to get it started ??? Now i have my VCDS working if i can help anyone in the northwest give me shout! On another note big thanks to CARL for sorting my parts out , quality service from A8 Parts ,recommended no problem!!!!!!
did you do an auto scan then a full clear of the codes as some battery replacement ones still seem to be present along with some really old faults from 2013.
I did a auto scan then cleared all codes then turned ignition off and locked and unlocked car then ignition on and done another auto scan?
There is a lot more in there than I would expect after it has been cleared down.
Either it needs a clear down again or there is something more. Almost like the wiring/ earthing has a problem which is unlikely on a modern car. |
It's throwing an error on the power management module. That can cause all manner of horrors.. Has someone jump started it wrong?
Also an error on the oil pressure sensor, not sure, but if that's throwing a wobbly, then the car may not fire in order to protect itself.
I have heard about the power control module before , i take it its not option 61 in vcds battery control? is there a way to test the module with vcds?
Im hoping to get home handy from work so i can go through all the fuses and check them.Can anyone point me to the location of the power control module? thanks again for all your posts so far!
PsYcHe , just thought , yes the vosa guys tried to jump it before they let my dad now it wasnt starting , mmmmmmm
So.. the battery may have died.. if the D3 isn't jumped properly, it can (and probably will) fry the power control module.
