Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 4th January 2015, 07:10 AM
Thread for all the D3 Retrofit threads and Tech info
Please let me know by PM of something you feel would beneficial to be added to the list.
A8 & S8 D3 Brochures Scanned
OEM reverse camera retrofit
Umbrella Holder retrofit
Facelift Tail lights retrofit
File Type: pdf 2-Current Flow Basic equipment from model year 2003.pdf (49.71 MB, 5802 views)
File Type: pdf 3-Service Manual 6-cylinder direct petrol injection engine (2 8 ltr 4-valve BDX & CJBA).pdf (14.75 MB, 2206 views)
File Type: pdf 4-Service Manual 6-cylinder direct petrol injection engine (3 2 ltr 4-valve BPK & BKH).pdf (8.72 MB, 2212 views)
File Type: pdf 5-Service Manual 6-cylinder engine ASN & BBJ mechanics.pdf (6.40 MB, 2627 views)
File Type: pdf 6-Service Manual 6-cylinder TDI engine (3 0 ltr 4-valve common rail ASB & BNG) mechanics.pdf (8.19 MB, 3765 views)
File Type: pdf 7-Service Manual 8-cylinder direct petrol injection engine (4.2 ltr 4-valve BVJ) mechanics.pdf (7.56 MB, 3080 views)
File Type: pdf 8-Service Manual 8-cylinder engine (3.7 ltr..4.2 ltr 5-valve BFM, BFL & BGK) mechanics.pdf (6.22 MB, 6760 views)
File Type: pdf 9-Service Manual 8-cylinder TDI engine (4 0 ltr 4-valve common rail ASE) mechanics.pdf (9.02 MB, 3108 views)
File Type: pdf 10-Service Manual 8-cylinder TDI engine (4 2 ltr 4-valve common rail BVN & BMC) mechanics.pdf (7.83 MB, 4058 views)
File Type: pdf 11-Service Manual 10-cylinder direct petrol injection engine (5 2 ltr 4-valve BSM) mechanics.pdf (7.66 MB, 3538 views)
File Type: pdf 12-Service Manual 12-cylinder engine (6 0 ltr 4-valve BHT, BSB & BTE) mechanics.pdf (6.42 MB, 2286 views)
File Type: pdf 14-Service Manual Automatic gearbox 09L four-wheel drive.pdf (4.74 MB, 3492 views)
File Type: pdf 19-Service Manual Direct petrol injection and ignition system (6-cyl 2 8 ltr 4-valve BDX & CJB.pdf (3.03 MB, 1621 views)
File Type: pdf 20-Service Manual Direct petrol injection and ignition system (8-cyl 4 2 ltr 4-valve BVJ).pdf (2.49 MB, 2314 views)
File Type: pdf 21-Service Manual Direct petrol injection and ignition system (10-cyl 5 2 ltr 4-valve BSM).pdf (2.34 MB, 2091 views)
File Type: pdf 22-Service Manual Electrical system General information.pdf (2.92 MB, 4271 views)
File Type: pdf 23-Service Manual Electrical system.pdf (9.10 MB, 6170 views)
File Type: pdf 24-Service Manual Fitting instruction for Airbag Key Switch.pdf (961.7 KB, 1902 views)
File Type: pdf 25-Service Manual Fuel supply system diesel engines ASB, ASE, BNG, BVN & BMC.pdf (1.70 MB, 3099 views)
File Type: pdf 26-Service Manual Fuel supply system petrol engines ASN, AUK, BBJ, BFL, BFM, BGK, BHT, BPK, BSB.pdf (2.88 MB, 3446 views)
File Type: pdf 27-Service Manual Fuel supply system - petrol engines BFL & BFM.pdf (1.59 MB, 2328 views)
File Type: pdf 28-Service Manual General body repairs exterior.pdf (5.52 MB, 5739 views)
File Type: pdf 29-Service Manual General body repairs interior.pdf (9.26 MB, 5671 views)
File Type: pdf 30-Service Manual Installation instructions for coolbox.pdf (574.2 KB, 3209 views)
File Type: pdf 31-Service Manual Installation manual for digital TV tuner.pdf (353.8 KB, 2863 views)
File Type: pdf 33-Service Manual Motronic injection and ignition system (6-cyl ASN & BBJ).pdf (1.45 MB, 1985 views)
File Type: pdf 34-Service Manual Motronic injection and ignition system (8-cyl BFL, BFM & BGK).pdf (1.23 MB, 3743 views)
File Type: pdf 35-Service Manual Motronic injection and ignition system (12-cyl BHT, BSB & BTE).pdf (1.32 MB, 1833 views)
File Type: pdf 36-Service Manual Multitronic 01J front-wheel drive.pdf (2.19 MB, 2356 views)
File Type: pdf 37-Service Manual Rear final drive 0AR.pdf (1.10 MB, 2164 views)
File Type: pdf 38-Service Manual Rear final drive 01R.pdf (2.25 MB, 2217 views)
File Type: pdf 39-Service Manual Running gear front-wheel drive and four-wheel drive.pdf (8.57 MB, 4028 views)
File Type: pdf 40-Service Manual TDI injection and glow plug system (6-cyl 3 0 ltr 4-valve common rail ASB & .pdf (2.73 MB, 7834 views)
File Type: pdf 41-Service Manual TDI injection and glow plug system (8-cyl 4 0 ltr 4-valve common rail ASE).pdf (2.24 MB, 2526 views)
File Type: pdf 42-Service Manual TDI injection and glow plug system (8-cyl 4 2 ltr 4-valve common rail BVN & .pdf (2.34 MB, 2218 views)
File Type: pdf 44-Servicing automatic gearbox 09E four-wheel drive.pdf (3.19 MB, 3294 views)
File Type: pdf 45-Servicing automatic gearbox 09L four-wheel drive.pdf (2.50 MB, 2171 views)
File Type: pdf 46-Servicing multitronic 01J and 0AN.pdf (3.95 MB, 2483 views)
File Type: pdf 47-Simos direct petrol injection and ignition system (6-cyl 3 2 ltr 4-valve BPK & AUK).pdf (1.64 MB, 1807 views)
File Type: pdf 48-SSP 282 Audi A8 03 - Technical Features.pdf (5.42 MB, 6012 views)
File Type: pdf 49-SSP 283 6-speed automatic gearbox 09E in the Audi A8 03 - Part 1.pdf (5.05 MB, 3176 views)
File Type: pdf 50-SSP 284 6-speed automatic gearbox 09E in the Audi A8 03 - Part 2.pdf (2.45 MB, 2612 views)
File Type: pdf 51-SSP 285 Running Gear in the Audi A8.pdf (3.55 MB, 2607 views)
File Type: pdf 52-SSP 286 New data bus systems - LIN MOST Bluetooth.pdf (2.85 MB, 2840 views)
File Type: pdf 53-SSP 287 Audi A8 03 - Electrical Components.pdf (1.86 MB, 4105 views)
File Type: pdf 54-SSP 288 Audi A8 03 - Distributed Funcitons.pdf (972.3 KB, 2677 views)
File Type: pdf 55-SSP 289 Adaptive cruise control in the Audi A8.pdf (2.30 MB, 2842 views)
File Type: pdf 56-SSP 292 adaptive air suspension in the Audi A8.pdf (2.43 MB, 3689 views)
File Type: pdf 57-SSP 293 Audi A8 03 - Infotainment.pdf (1.92 MB, 3042 views)
File Type: pdf 58-SSP 327 Audi engines - Chain drives.pdf (3.87 MB, 2675 views)
File Type: pdf 59-SSP 365 Audi 4.2 l V8 TDI with Common Rail Injection System.pdf (828.5 KB, 2430 views)
File Type: pdf 60-SSP 366 Audi Infotainment Systems ´05.pdf (1.65 MB, 3112 views)
File Type: pdf 61-SSP 376 5.2 litre V10 FSI engine.pdf (947.3 KB, 7458 views)
File Type: pdf 62-SSP 377 Audi 4.2-litre V8 FSI engine.pdf (1.39 MB, 2481 views)
File Type: pdf 63-SSP 385 6-Speed Automatic Gearbox 09L 0AT 0B6 0BQ 09E.pdf (10.14 MB, 21980 views)
File Type: pdf 64-SSP 923603 The 5.2L V10 FSI Engine.pdf (14.79 MB, 3906 views)
File Type: pdf 65-SSP 994303Audi Adaptive Air Suspension.pdf (2.18 MB, 5287 views)
File Type: pdf How to recover a bricked Audi MMI 3G.pdf (434.8 KB, 18563 views)
File Type: pdf audi-mmi-2g-high-hidden-menu-guide.pdf (307.6 KB, 10613 views)
File Type: pdf Definitive Guide to Installing Auxiliary Heating to your A8 D3.pdf (1.28 MB, 3914 views)
