Old 9th February 2015, 10:10 PM
Urbtree Urbtree is offline
Default A8 Timing out?
Ok so forgive me If this turns into a waffle but I guess you need the story.
Bought a 2000 A8 D2 2.8 recently. (picture in introductions)
after about a week it started making a noise that I attributed to a tensioner on the aux belt.
Turns out I got it to the garage just in time as the water pump had died and dropped water all over the tensioner below it causing catastrophic failure (loss of all ball bearings) and very nearly toasting the car.
I took it to my very competent tame mechanic who fitted a new cambelt kit tentioners water pump and rollers in just under 2 hours.
He told me with the bearing going he had no correct reference point so had to guess the belt position (possible misquote here)
I've since read about the special tools and about having to take the front end off to do the job.
I've also read a lot of posts on here that tells me this isn't uncommon.
Everything works fine and runs but I now have a lumpiness at tickover that wasn't there before.
We both suspect the timing may be slightly out and the VCDS log kinda confirms it.
What I need to know is
1. if I buy the special tools will that allow him to set it up properly if he has no correct reference point.
2. where do I get the tools and a ball park price if possible
The car does have one or two other issues but I'm kicking off here with the priority cases.
Thanks in Advance
Mike
VCDS LOG (Excuse me if its incorrect its the first time I've used it)
Monday,09,February,2015,11:08:17:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ4DZYN008033 License Plate: X307WRC
Mileage: 132212 Repair Order:
Address 01: Engine Labels: None
Control Module Part Number: 3B0 907 551 AB
Component and/or Version: 2.8L V6/5V G 0001
Software Coding: 04553
Work Shop Code: WSC 00202
Additional Info: WAUZZZ4DZYN008033 AUZ7Z0X1202885
VCID: 63C54907F1A06306E91-5000
3 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
18058 - Powertrain Data Bus
P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
17746 - Camshaft Position Sensor (G40)
P1338 - 35-00 - Open or Short to Plus
Readiness: 0000 0000
2000 A8 D2 2.8 none Quattro
1990 Lada Niva Cossack Jacked
2008 Transit 140
www.tyresbarrow.co.uk
