Old 16th March 2015, 12:26 PM
barzya8 barzya8 is offline
Default Central locking
Hi Guys,
Could anyone throw any light onto the fault code detailed below.
Is this the central locking pump gone south.
It will not work at all, no noise from the boot either.
Car can be locked and unlocked manually using the key. rear doors and passenger front door have to have the buttons pressed down and locked.
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Control Module Part Number: 8LO 862 257
Component and/or Version: ZV-Pumpe, DWA, Funk
Software Coding: 10184
Work Shop Code: WSC 65535
VCID: 112DB17771F9
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Unlicensed Version. Not all DTCs
35-00 - will be decoded.
01372 - Unlicensed Version. Not all DTCs
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Unlicensed Version. Not all DTCs
Also the Airbag light came on again, but this time its the rear passenger side seat sensor. Is there a way of fitting a resister to the rear seat sensor?
Address 15: Airbags Labels: Redir Fail!
Control Module Part Number: 4D0 959 655 C
Component and/or Version: Airbag 7 Audi D02
Software Coding: 00224
Work Shop Code: WSC 02314
VCID: 326F1EFBD4BF
1 Fault Found:
01216 - Seat Occupant Sensor; Passenger Side Rear (G178)
32-10 - Resistance too High - Intermittent
Many thanks for any responses.
Barzya8
Guildford, Surrey
Bose sound system.
Audi Navigation Plus.
20 inch Final Edition alloys
Old 16th March 2015, 04:17 PM
Just as an addition, I can now hear the pump working, but not opening or closing any doors. It runs for about 10 seconds and then stops when using the key only. Nothing happens when trying to use the remote on the key.
Guildford, Surrey
Bose sound system.
