D3 - Transmission Gearboxes, diffs, drive shafts. |
hi guys,
and i'm new to this Audi [having spent some time on other Audi related ones in the past]. i recently bought an A8 L and it's been a magnificent car for months only to notice slight judder/shudder [e.g. hesitance] recently. it is mainly manifested when eng temp is still relatively low in 2nd and 3rd gear when moving slowly through gears @ 12-1600 rpm. If one was to push the accelerator pedal hardly you won't notice anything. i read several articles about g'box oil change but before i go down that route could anyone shed any lights what could be an issue... car has 140k miles on the clock and it has been maintained regardless of cost by the Audi main dealer. i also have access to VCDS and have attached extract re only transmission related error... Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI A000AGMª0070 Revision: --H01--- Serial number: AUX3Z0F0383728 Coding: 0011773 Shop #: WSC 00097 210 80549 VCID: 224B0C03FD3A2A0EA27-8077 1 Fault Found: 006217 - Please check DTC Memory of Transmission Controller P1849 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 227660 km Time Indication: 0 Date: 2015.02.05 Time: 00:00:07 Freeze Frame: RPM: 0 /min Torque: 3.9 Nm Speed: 0.0 km/h (no units): 0.0 Voltage: 6.54 V Torque: 795.6 Nm Bin. Bits: 11000000 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 P HW: 09E 927 156 B Component: AG6 09E 4,2lTDI RdW 0030 Revision: --H01--- Serial number: 0076614 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 306FF64BA3D6889E243-8065 No fault code found. |
