Old 28th May 2015, 10:23 PM
Default Current flow diagram help
Hi all,
What does the 271 refer to in the highlighted area?
Matt
Old 28th May 2015, 10:33 PM
The number refers to a column on another page, if your using Bentley and sometimes Etka if you click the number it hyperlinks to that part of the manual
Old 29th May 2015, 03:47 PM
Thanks Del
I was working off PDF's, I'll try to install Elaswin again as didn't have much luck with it last time. Does Elaswin include pin out descriptions? I'm currently doing my research on the J519 module.
Name:	4E0 J519 copy.jpg
Matt
Old 29th May 2015, 05:54 PM
You get the same kind of info that's in the circuit you first posted Matt
