Old 28th May 2013, 08:48 AM
Default Pagid Pads - cracking
Having been trying to get to the bottom of brake shudder which started around the time of pad/disc renewal late last year, I have just had the upper control arms replaced which made it a whole lot better but didnt eradicate it. (They had been picked up at the MoT).This week my garage replaced the (Audi) discs (hopefully under warrranty) and the (Pagid) pads (ditto) in trying to find the cause. Result - shuddering gone! The shudder used to get worse with use at speed (heat).The mechanic was concerned about the state of the pads and as can be seen from the photos there is large crack in one (inboard pad) and discolouration of some of the others.
I know that some state that Pagid's reputation for quality was going downhill but this looks like really poor manufacturing quality.
Name:	Pagid Pads 001.jpg
ID:	6090   Click image for larger version
Name:	Pagid Pads 002.jpg
ID:	6091   Click image for larger version
Name:	Pagid Pads 003.jpg
ID:	6092   Click image for larger version
Name:	Pagid Pads 004.jpg
Old 28th May 2013, 09:05 AM
Glad it's sorted at last, David.
Old 28th May 2013, 10:47 AM
roboblob roboblob is offline
picture 4 ,the hole on the left . That looks like copper slip ,I would be concerned why it got there, did an apprentice fit the pads and put it on the wrong side of the pads ?
in fact both pads with wires seen to be contaminated.
Old 28th May 2013, 11:33 AM
You are right - it is copper slip - but the contamination came after they were removed. In fact it was from the way they had been put back in the box for me to examine (the garage senior mechanic did the job and ALWAYS keeps the parts for me to examine - he know what I'm like!!)
Old 28th May 2013, 11:40 AM
Use Audi parts only. They are expensive, but they at least guarantee basic level of quality.
Old 28th May 2013, 12:48 PM
Or at least parts manufactured in Europe/to European quality standards.
With some components you can't be absolutely certain that buying genuine actually means the component is fit for purpose - it could've been on a shelf for 10 years or more which doesn't do rubber in particular any favours if the conditions of storage aren't perfect. Will become more of an issue over time as we look to obtain spare parts
Old 28th May 2013, 03:30 PM
Exactly, I bought Pagid from ECP for the last RS 6, £54.00, they were £250 from Audi for apparently the ''same'' part. They weren't the same part, they lasted four months and I went and bought the pads from Audi in the end. I don't do OE anymore, OEM from Audi or TPS only. Need a set of front pads for the C6 now, £400.
