Old 7th January 2022, 09:20 PM
I gave all the leather another coat of leather care and then started putting it back in the car
While the rear door cards were off I swapped the triangles for some nicer ones
Mike came over today and helped me finish off the interior
Now thats all done, time for the mechanical stuff!
Not updated the totals for a bit:
240 hours, £3412
Parts used:
PS hoses (refurb, £200)
PS hose brackets (used)
NSF upper rear arm (used)
NSF lower rear arm (used)
NSF wheel bearing (used)
CV boot (£12)
Suspension brace (used)
Boot lid (£150)
FE wheels (£500)
Window motor (£50)
Headlight level arm joints (£15)
Radiator (£300)
Belt idlers (used)
Accessory belt & idlers (used)
Snub mount (£60)
Air filter (£6)
Wiper mechanism & motor (£120)
Air box trim (£10)
Intake duct (£10)
Bumper (£200)
F125 (£1)
Exhaust clamps (£30)
Boot grommets (£15)
Brake fluid (£20)
Wiper trim (£50)
Platinum carpet (£25)
Central locking pump (£60)
Lateral Acceleration Sensor (£20)
N/S seat belt (£18)
Potions and microfibres (£120)
Wiper blades (£30)
Bosch S3 019 battery (£85)
Bosch lambda sensors 2x (£120)
Parking sensors 2x (£40)
SAI removal plates + map (£65)
Fuel pump (£140)
Paint correction (£600)
Dent removal (£180)
Headlining & interior trim (used)
Aluminium roof trim 2x (£160)
ID:	27609   Click image for larger version
ID:	27610   Click image for larger version
ID:	27611   Click image for larger version
ID:	27612   Click image for larger version
ID:	27613   Click image for larger version
ID:	27614   Click image for larger version
Old 7th January 2022, 11:06 PM
Natty little hole under the passenger armrest
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 8th January 2022, 07:40 AM
That's for the phone cable which plugs in to the block under the armrests. Or, used to anyway. Not a lot of use these days, since most modern phones don't fit in to the armrests.
Old 8th January 2022, 09:16 AM
I always liked the use for that slot that one of the old members did, where he rigged it up as an iPod holder. Although finding one of those is quite challenging these days!
Old 8th January 2022, 10:39 AM
So nothing like a USB attachment for a USB music stick that could connect in to the RNS-D unit?
Paul
Gosport UK
Honda Jazz
Old 8th January 2022, 01:52 PM
Funnily enough, I was looking at the phone connector yesterday and thinking that it could be reused as a USB charging point An aux input is an interesting idea...
Old 8th January 2022, 07:07 PM
Everything removed from the top
On to the suspension - the left hand side came off no problem since that had been in bits earlier
The right hand side put up more of a fight so the whole lot came off in one chunk
The pinch bolt and tie rod are seized so I'll deal with those later
Everything off underneath now too
Empty wheel wells
Just the four subframe bolts holding it in now so it can come out first thing in the morning
ID:	27616   Click image for larger version
ID:	27617   Click image for larger version
ID:	27618   Click image for larger version
ID:	27619   Click image for larger version
ID:	27620   Click image for larger version
ID:	27621   Click image for larger version
ID:	27622   Click image for larger version
Old 8th January 2022, 09:52 PM
Audifan Audifan is offline
Amazing work!
Old 9th January 2022, 08:13 AM
RICKY D's Avatar
RICKY D RICKY D is offline
I love a good WITW thread
I still think MJ should have a “D2 Doctor” or “Doctored” badge that could be applied to any vehicle that passes through the workshop
Old 9th January 2022, 10:08 AM
That's all I've got:
