Old 1st February 2022, 12:47 PM
Ronin Ronin is offline
£30 tensioner is paying off ok for me for now.... if it fails I'll start a thread about it
Old 1st February 2022, 09:21 PM
Bank 1 this evening
The gauze has split on this one and the middle has gone through the tensioner hence the startup rattle
Cam cover cleaned and new gasket installed
Sealant in the corners
Back on, two new tensioners installed
Thats all the internal work done on the engine
The replacement manifold is almost ready for paint. Serendipitously, this is from my grey S8's original engine so I know there's only 113K miles on it.
I know this one is from my engine because the previous owner had a can of orange paint, and for some reason painted random bits of hardware and engine parts with it This includes the crank pulley, fan pully, and inexplicably, these two nuts. I'll clean this off before it goes back together.
Since the injector rail is off for paint I will replace all the injector filters and seals
ID:	27775   Click image for larger version
ID:	27776   Click image for larger version
ID:	27777   Click image for larger version
ID:	27778   Click image for larger version
ID:	27779   Click image for larger version
ID:	27780   Click image for larger version
ID:	27781   Click image for larger version
ID:	27782   Click image for larger version
ID:	27783   Click image for larger version
Old 2nd February 2022, 08:34 AM
I'm so glad I took your advice removed my filters on the tensioners now
Old 2nd February 2022, 08:55 AM
If that happens, it'll either be a very short or a very, very long thread...
Old 2nd February 2022, 09:04 AM
You are right but for a price of 2 oem tensioners ill get a used pre-fl 4.2 v8 in it
Old 2nd February 2022, 09:34 AM
You really don't want to be mixing PF and FL drivetrains - trust me on that one! I do have an FL 4.2 on the shelf though
Old 2nd February 2022, 08:00 PM
Injectors tonight.
Having struggled to get the filters out of the PF injectors, I made a tool The injector fits in the hole, then a self-tapper is screwed in to the filter
Then a trim removal tool can be used to lever against the tool and pop the filter out
thus:
All the filters removed. They are actually all clean and in perfect order, but I didn't know that until I took them out
At this point I was thwarted as the new filters are a slightly different size so I had to stop. I need to query this with the supplier tomorrow before proceeding, so I finished off prepping the manifold for paint which will hopefully go on tomorrow.
ID:	27785   Click image for larger version
ID:	27786   Click image for larger version
ID:	27787   Click image for larger version
ID:	27788   Click image for larger version
Old 3rd February 2022, 03:24 PM
Nope. stick one of these in......
https://www.partsworldperformance.co...ngine-19369333
With a 5HP19 that will work
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 3rd February 2022, 03:54 PM
Actually I do know a chap who could build a 5HP to take that beast. Only problem is, the crank pulley would be roughly where the number plate lives
Old 3rd February 2022, 04:19 PM
Talking
I would name the thread: "The revenge of 2.8 owners"
