Old 27th February 2022, 10:59 AM
Ronin Ronin is offline
Good luck!
I think buying premium luxury cars also translates to more luxurious and less aggravating service procedures for the mechanics, yet another reason to own a D2
https://www.youtube.com/watch?v=k2BYHH42Rq4
^this guy is a legend, he does clutches on peoples drive for a living
Old 27th February 2022, 06:11 PM
I just skipped through that to the point where he dropped the gearbox down onto his gut and rolled it off to the side!
Old 27th February 2022, 07:03 PM
S81 S81 is offline
Any idea of how long it took him from start to finish?
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 27th February 2022, 07:29 PM
Well, I failed to finish it in time I needed a couple more hours, but just ran out of energy at 8pm, as did Lucy who was helping so we had to stop. Its all back together and working, but I can't check the gearbox fluid level as the power steering pipes are blocking the drain plug. I'll finish it off tomorrow and Lucy can go to work in the Allroad
Old 27th February 2022, 07:58 PM
S81 S81 is offline
I was thinking that guy didn't do it in an hour ,were you replacing the fluid as mantance or did it need done as part of the clutch works
Daily driver
Previously owned
Old 27th February 2022, 08:32 PM
Gearshifts have been getting a bit notchy so I changed the oil while it was out. I put the new oil in before I put the gearbox back in, but I need to check the level before sending it home.
Old 28th February 2022, 03:46 PM
So TT gets a loan Allroad. Do the D2 owners get a choice of your vast stock to tootle around in?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 28th February 2022, 04:25 PM
That will be one of the Murple's duties
(assuming anyone is brave enough )
Old 12th March 2022, 08:00 PM
I've been steadily chipping away at this since the TTing, and got all the front end done.
New AC condenser fitted. This is a Thermotek which is the least dreadful fitment of the aftermarket units. They're all abysmal, but this at least fits without cutting up the front panel.
New rubber strips between the bumper and wheel arch
Bumper back on, which was actually a bit premature as I still need to align the front end, but it looks like progress
Refurbished springs, including original colour markings
Assembled with repainted dampers and new top mounts
Installed on the car, plus a balljoint headlamp arm
Looking quite tidy now
On to the rear end. Marcel came over to help today and so we got lots done
Not quite as shiny as the front!
Rear subframe removed
With significant weight removed from the rear, but the engine and box in the front, I've strapped the body to the lift as a safety measure. Tomorrow I will put the wheels in the boot to balance out the weight
Its rather crusty
So crusty in fact, that it is beyond salvation The rust flakes off in large chunks
The metal is paper-thin in places so this is bound for the scrap yard. A major setback since this one was supposed to get blasted and painted and put on the murple to continue the cycle. I will have to find another to replace it.
We removed the heat shields which were held to the body with self-tappers The spurious holes will be filled with rivets and seam sealer, whereas the ones where there should be studs will get rivnuts
Massive thanks to Marcel for coming over and getting grubby
ID:	27974   Click image for larger version
ID:	27975   Click image for larger version
ID:	27976   Click image for larger version
ID:	27977   Click image for larger version
ID:	27978   Click image for larger version
ID:	27979   Click image for larger version
ID:	27980   Click image for larger version
ID:	27981   Click image for larger version
ID:	27982   Click image for larger version
ID:	27984   Click image for larger version
ID:	27985   Click image for larger version
ID:	27986   Click image for larger version
ID:	27987   Click image for larger version
ID:	27988   Click image for larger version
ID:	27989   Click image for larger version
ID:	27990   Click image for larger version
ID:	27991   Click image for larger version
ID:	27992   Click image for larger version
Old 12th March 2022, 08:25 PM
Happy to serve as human forklift 👍
