Old 12th March 2022, 08:43 PM
S81 S81 is offline
As a matter of interest When you say align the front end is that just to make the bumper/gaps align or is it something more / different
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 12th March 2022, 09:03 PM
Yes, exactly that. The position of the front panel defines how the bonnet sits in relation to the wings and headlights so that needs setting first, then once that is all correct, the bumper can be adjusted to suit.
Old 13th March 2022, 06:37 AM
That rear subframe looks pretty dreadful! Did this car live by the sea at some point? Reminds me of the state of my GL5 that lived in Poole for most of its life…..
Old 16th March 2022, 07:48 PM
Parked for 6 years on grass or possibly gravel and weeds I think.
Rear bushes. Mostly self-explanatory. Not a fan of the Febi bushes for the hub as the metal is very thin making them likely to crush when they go in. I'll investigate the Febest versions, or spend the money on the genuine D3 items in the future.
Fuel tank straps. They are attached to studs pressed in to the body. When removing these nuts one has to be extremely careful not to put too much torque on them as the studs will just spin in their holes and then you're going to have a very bad day.
After soaking in WD40 for a couple of days, then cleaned with a wire brush and a pick, then soaked in WD40 for a bit longer, I'll screw a spare M8 nut on to clean up the thread. Once this goes on and off by hand, only then will I loosen the strap nut, as I know it'll come off cleanly. This is the sort of job where you need a 1/4" ratchet, maybe 3/8" max, so as not to put too much torque on anything.
With the straps on the right hand side off, the tank drops just enough to get to the bolts holding the horribly rusty exhaust hanger
Powdercoated exhaust hanger and tank straps, with new nuts.
Much better
ID:	28014   Click image for larger version
ID:	28015   Click image for larger version
ID:	28016   Click image for larger version
ID:	28017   Click image for larger version
ID:	28018   Click image for larger version
ID:	28019   Click image for larger version
ID:	28020   Click image for larger version
ID:	28021   Click image for larger version
ID:	28022   Click image for larger version
ID:	28024   Click image for larger version
ID:	28025   Click image for larger version
ID:	28026   Click image for larger version
ID:	28027   Click image for larger version
ID:	28028   Click image for larger version
ID:	28029   Click image for larger version
ID:	28030   Click image for larger version
ID:	28031   Click image for larger version
ID:	28032   Click image for larger version
ID:	28034   Click image for larger version
Old 16th March 2022, 07:58 PM
Ronin Ronin is offline
Is the hanger in second to last pic one piece? I ordered 2 but none of them are this big 😥
Old 16th March 2022, 08:25 PM
scottmgibb scottmgibb is offline
That is great information! Did you just get the existing straps and hanger cleaned up and powder coated?
Audi S8 D2 2002
Old 16th March 2022, 08:48 PM
Yes, 4D0253093A.
I have a complete spare set so got them blasted and powdercoated in advance so I can just swap them over. That was the plan with the subframe too, which hasn't gone quite so well.
Old 17th March 2022, 09:42 AM
Hm, it looks like V8 hanger differs from V6, so i think i got the right one
Old 17th March 2022, 12:11 PM
Ah yes, iirc the V6 only has one in that position, so #6 for the V6 is #12 for the V8.
Old 17th March 2022, 08:26 PM
Doing the rear brake pipes while the subframe is off. The two unions by the tank are pretty crusty. One of these pipes is staying put, the other one is getting changed.
The brake hose bracket has completely corroded through which is vexing
The top part of this should be attached to the body, but its just turned in to fluff
This is the remaining stump of the bracket
The solution will involve a new bracket and structural adhesive.
ID:	28036   Click image for larger version
ID:	28037   Click image for larger version
ID:	28038   Click image for larger version
ID:	28039   Click image for larger version
