Old 18th March 2022, 11:19 AM
Is that bushing squished like that due to the removal process or like that when removed? If its like that when removed is it due to the arm being fully bolted prior to the car suspension sitting normally, therefore under stress?
Powdercoated exhaust hanger and tank straps, with new nuts.
Much better
After all the underside is done I can picture you reclining in your chair (under the car), shades on, tequila sunrise in hand and admiring the view......
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 18th March 2022, 01:13 PM
I may or may not have done that already with the front end
The outer edge being mangled is because I run a drill down it to separate the rubber from the metal sleeve. Usually they are already separated most of the way round, so the drill just finishes it off so it pops out. The small chunk missing from the sleeve at the top is from me trying to lever it out before releasing it with the drill.
I'm doing the opposite lower arm this evening so I'll get some more pics.
Old 19th March 2022, 08:40 PM
This is the other control arm. This is the split bushing, the centre of which just pops out with a screwdriver
This is the other one. You can see how the rubber is detached from the outer sleeve
Not detached enough to pop out though. The sleeve is so corroded that it just splits with the torque from the screwdriver
Drill round the edge - this was so bad it needed a single hole, and then the drill pulled itself all the way round
Removed
Sleeve left in place
Saw through it to relieve the tension holding it in
Sometimes one cut is enough. In this case it wasn't so I made a second cut and then punched the middle bit out, then the sleeve came loose and popped out.
On to the floorpan, prepping for the subframe to go back in. This is one of the holes from the self tappers used to hold the heat shields on, now with a rivet and seam sealer
Water tight
Same thing again but in the tunnel
Grind off the stump of the stud, then open out the hole while pulling it down with the rotary tool
Blind rivnut inserted, again with seam sealer
and a bi-thread stud in the rivnut, held in place with blue loctite so it won't fall out, but could be removed in the future if nedessary. There were four more like this.
This is the new brake hose bracket which will be bonded in place. I've removed the seal sealer and e-coat behind it so its clean aluminium on both sides. The little hole is coincidental and just happened to be in the stock I was using. This piece was going to be the mockup, but it actually worked first time so the hole gets to stay and will provide extra surface area for the adhesive.
ID:	28046   Click image for larger version
ID:	28047   Click image for larger version
ID:	28048   Click image for larger version
ID:	28049   Click image for larger version
ID:	28050   Click image for larger version
ID:	28051   Click image for larger version
ID:	28052   Click image for larger version
ID:	28053   Click image for larger version
ID:	28054   Click image for larger version
ID:	28056   Click image for larger version
ID:	28057   Click image for larger version
ID:	28058   Click image for larger version
ID:	28059   Click image for larger version
ID:	28060   Click image for larger version
ID:	28061   Click image for larger version
Old 20th March 2022, 06:59 PM
Subframe today, but I started by glueing the brake hose bracket on so that could be curing. The adhesive has a nominal strength on aluminium of 22N per mm˛. The bracket has an area of 616mm˛ which gives 13552N of holding force in ideal conditions, or 1.3 tons. I reckon that should hold a brake hose
New bolts. I've used the D3 toe adjustment bolts as they're only 4mm longer than the D2 ones. I got mk5 Golf camber bolts, but unfortunately they are missing 8mm of thread on the end so aren't quite long enough. The D3 camber bolts are 10mm too long, so I may have to just get the Febest ones.
The two long ones on the right are for the outer toe rod joint, which are from an Amarok, and 5mm longer than the D2 bolts. We probably should have an alternative parts thread where I can list all this...
All assembled
It was about this point where my phone battery died, so no more pics unfortunately. I had to swap the headlight level sensor, and made a new arm for that at the same point. The rear dampers are painted and back in too.
There are a couple of jobs left before putting it back in the car - the diff mount bolts were on back order so those need swapping, new camber bolts as noted, and a few other bits of hardware. I'd also like to get the brakes assembled while its sitting on pallets and nice and easy to get to.
Finally, I need to make some alignment sleeves to line it up with the rear mounting holes, as the tool I made when I did Ricky D's doesn't work with the D3 bushes. Those are 20mm inner diameter, whereas the locating holes are 21mm diameter, so I'll print up some simple sleeves for these. There's no load on them as they are purely used to line it up, and being printed there's no issue leaving them in place.
ID:	28065   Click image for larger version
ID:	28066   Click image for larger version
ID:	28067   Click image for larger version
ID:	28068   Click image for larger version
Old 20th March 2022, 07:39 PM
S81 S81 is offline
This is really pretty much a full refurbishment,are you looking at 300 plus hrs ?
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 21st March 2022, 10:11 AM
Ronin Ronin is offline
Nice touch with the carpet on pallets.
A typical workshop would probably just use 2 transmission stands or something and scratch the subframe.
Old 23rd March 2022, 03:13 PM
The time and effort to 'do it right'
I would have just stuck a rivnut in there and bolted it
Paul
Gosport UK
Honda Jazz
Old 23rd March 2022, 05:35 PM
Presumably Rivnuts etc are not aluminium. Is there therefore a potential for galvanic corrosion in future, or does your use of sealant insulate he different metals from each other?
Old 23rd March 2022, 08:44 PM
I have aluminium rivnuts where they are appropriate, and considered one here but I don't have a reference for what's behind this sheet metal so adhesive was the way to go.
Now covered in seam sealer
New fuel filter
The old one was dated 2002 so likely the original
This is the D3 camber bolt which is 10mm longer than it needs to be. Its ugly but it does the job.
ID:	28076   Click image for larger version
ID:	28077   Click image for larger version
ID:	28078   Click image for larger version
Old 26th March 2022, 07:17 AM
Changed at recommended intervals
I wonder what it looks like inside?
Paul
Gosport UK
Honda Jazz
