Old 10th June 2018, 10:55 PM
27litres's Avatar
27litres 27litres is offline
Love these threads too!
What was that anti-hologram polish for the wood trims?
And did you apply it by hand?
I tried polishing up a couple of sections of my trim using Maguire's plastic trim polish and a microfibre towel. Came up much better than when I started, but I couldn't get rid of those holographic swirls.
You might have to send me some
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 11th June 2018, 06:32 AM
B@fink B@fink is offline
Looks good....sooooooo much work. Worth it. It's what I think Roy Castle would have called "dedication" :-)
Old 11th June 2018, 07:21 AM
It was actually a 4-stage process on some of the really bad bits in the centre console, similar to polishing headlights but a slightly lighter touch. I wet-sanded with 3000 then 5000 to get most of the light scratches out, then polished the sanding marks out with Farecla G3 then G10, and finally brought out the full gloss with Koch Chemie M2.01 anti-hologram, all using foam pads in the battery drill.
Some parts have quite deep scratches which won't come out this way, but if they're shiny enough you can't see the scratches once the parts are in the car. The handbrake trim and the one above the rear vents really need re-painting so I pinched them from the other FE for the meet
Old 18th June 2018, 09:33 PM
Some pics of fitting the exhaust. The factory system is made in one piece, and you split it at the rear diff when replacing parts of it, or removing parts for access to other things. In my case, I split it when I fitted the towbar. Slightly unfortunately, the Supersport backbox is designed for the system to be split rather further back than I chose to do it, leaving a bit of an air gap:
Luckily, I still had Vera's scrap exhaust so I could salvage the needed pipework from this
Also somewhat vexing, Supersport didn't account for the factory towbar in their design I cut a large chunk out of the box until it cleared, and then welded a plate back in but forgot to take a pic of the result.
Welded in the pieces I salvaged from Vera's middle box so that the new backbox met up with my middle box so it all fits nicely
I'm very pleased with the sound from it, as a few of you heard at the meet. Nice and rumbly without being too loud. There's a bit of drone at 2000rpm, but the S8 gearing means its rarely in that range on the move, and if it is, just knock it in to 'S' to drop a gear and get up to 3000. It also makes a very subtle grumble on over-run.
ID:	19551   Click image for larger version
ID:	19552   Click image for larger version
ID:	19553   Click image for larger version
ID:	19554   Click image for larger version
Old 18th June 2018, 10:03 PM
My new 20" wheels really highlighted how tired the rear suspension bushes were getting. There was a shimmy at 40-50mph, and on the twisty bits I could feel the back end squirming about. I wanted to do them before the meet but just ran out of time so did them this weekend instead.
The bushes didn't look that bad, and would still pass an MoT no problem, but they were definitely done for.
The disc splash plates had seen better days too, and with the new wheels they were really obvious and bugged me at the meet! I should have ordered new ones for the weekend but forgot
They came off nicely though
Forgot to loosen the hub bolt while the brake disc was still on. Never mind!
Compressed the spring to get the lower arm out
Lower arm off
The split bushes were pretty manky - the rubber just popped out with a screwdriver! There was only about 1 sq cm left bonded.
The larger bush looked ok, but again hardly any of it was still bonded
The hub bush was even worse
Everything removed
I took the opportunity to replace the toe adjustment bolt since these often seize in to the toe arm, meaning you can't adjust the wheel alignment and have to get creating with a sawzall to change the arms. The bushes in these arms were perfectly fine so I put them back on. Its weird how all three lower bushes at the rear completely disintegrate yet the upper lot hardly wear at all. Plenty of copper grease on the bolts will ensure they don't seize in the future.
New bushes fitted and ready to go back on.
I forgot to take any pics of it going back together, or fitting the bushes, but thats all covered in Big Red's thread so doesn't need repeating here
Since I was going to be able to complete the job at the weekend I sanded down the splash plates and re-painted them rather than waiting a few days for new ones to come. I would just replace them on a customer car since it's cheaper, but I wanted it all finished
While the car was on the lift I also addressed the screech from the front brakes. Despite frantic filing on the Friday morning before the meet while Johannes was patiently waiting to leave, three of four pads were still too tight in the calipers. There's no corrosion under the pad carriers - the pads just don't fit properly
I spent some time on them this time and noted where the pads were tight and filed them down a tiny bit at the time so they were free in the calipers but not rattling about, then greased up all the moving edges. I also lightly sanded the friction surface to get rid of any glazing that might have occurred during the drive round the Peak District and then reassembled everything.
I managed a road test this time and she drives sooo nicely now Totally stable and no shimmy. The brakes actually feel pretty good for the first time since I got the car, and no more screech
ID:	19561   Click image for larger version
ID:	19562   Click image for larger version
ID:	19563   Click image for larger version
ID:	19564   Click image for larger version
ID:	19565   Click image for larger version
ID:	19566   Click image for larger version
ID:	19567   Click image for larger version
ID:	19568   Click image for larger version
ID:	19569   Click image for larger version
ID:	19571   Click image for larger version
ID:	19572   Click image for larger version
ID:	19573   Click image for larger version
Old 19th June 2018, 07:37 AM
Regulus Regulus is offline
It has a deep rumble in idle. I heard that a few times when we were out on the road, right behind you. Sounded better than any other car, I believe.
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 19th June 2018, 08:16 AM
Nice work MJ. And again thanks for the photos, they give confidence to a home mechanic like myself.
What sort of torque did you need to remove the hub bolt?
Matt
Old 19th June 2018, 08:50 AM
Djinny's Avatar
Djinny Djinny is offline
Is it perfect now? *curious*
S8 FL manual drive, 11/1999, pelican blue, customized by the Quattro GmbH, KAW 60/40, Supersport silencer, 19" from the S8 D3.
LPG & 385mm front brakes (D3).
Old 19th June 2018, 10:14 AM
Enough to start bending a 3-foot breaker bar. That's my tightening torque for them as well
Almost
Old 19th June 2018, 12:48 PM
Let's put some numbers on this...
40kg force on the bar, which is 392 Newtons, on a 0.914m bar equates to 358 Nm
Matt
