Old 9th April 2018, 07:05 PM
nice work as usual mj
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 9th April 2018, 08:17 PM
Not a great deal to report today. Mostly removing ancillaries from the engine, and removing the centre exhaust silencer which turned out to have a hole in it. Luckily the excellent folk at A8parts had a full system in stock and were able to cut it to the exact length needed to fit with Vera's Supersport back box so dodged a bullet there!
I also removed the LPG injectors from the old engine. You can see the LPG adapters just underneath the original petrol injectors:
Pretty neat little things actually, which save you from having to drill the inlet manifold. I don't like the way the fuel rail is suspended on nuts and bolts though so I will tidy that up
The old engine all nekkid
I had to adjust my engine and gearbox separatey thing to fit the manual gearbox
Once the engine and 'box were split I cleaned up the gearbox and removed all the clutch fork stuff as that's all being replaced with new along with the clutch and flywheel.
Lots of o-rings and things coming tomorrow so I can reattach all the original water pipes etc to the new engine and start putting it back together
ID:	18360   Click image for larger version
ID:	18361   Click image for larger version
ID:	18362   Click image for larger version
Old 9th April 2018, 08:26 PM
You didnt disappoint MJ! I was waiting for the nightly update
What are doing with the old engine and LPG gubbins then?
Old 9th April 2018, 08:37 PM
The LPG is going back on the new engine although it'll run on petrol until its properly run-in.
The old engine is going in my A4 racecar. Since it only uses oil under 3000rpm, a track car is the perfect new home for it
Old 9th April 2018, 09:28 PM
Thanks MJ, your write ups are fascinating and I love seeing how you renew these cars.
Old 10th April 2018, 07:17 AM
......you renew these cars.
MJ
Do you get so heavily involved with the D3 S8? Engine replacements etc......
Anyway wonderfully informing posts, I love following these threads.
Old 10th April 2018, 08:00 AM
Exclusively D2s
