Old 31st March 2019, 03:34 PM
Mark, I just checked if they fit anything else and they are also used in the D3 so we should have supply for another 5 years in theory.
Great That's good to know.
Old 31st March 2019, 06:16 PM
After my bad experiences of the local Audi indy people in my (relatively) new neck of the woods, it is wonderfully reassuring to have my car in MJ’s capable hands. Well worth the 4 hour drive and a couple of weeks or so without a car. And reading a ‘what’s in the workshop’ write up on your own car is brillaintly exciting!
MJ made me very welcome and we did a reccy with the car on the lift, so there are a couple of other jobs to be done as a result. And I’ll be back at a later date for a rear subframe rebuild.
And as an added bonus, I had a short trip in MJ’s car when she gave me a lift to a services to meet up with a friend for a lift home. Even from the passenger seat, you can tell how ‘tight’ MJ’s car is - it’s like a brand new car (which it pretty much is!). And the interior is a beautiful place to be - the red leather and black trim is a very pleasing combination.
I can’t wait for the next post - thanks MJ!
Old 31st March 2019, 08:30 PM
This morning's activities:
ID:	21047   Click image for larger version
Old 31st March 2019, 09:12 PM
This afternoon was spent removing engine parts and prepping it for cleaning
I think this is where most of the gunge on the lower half of the engine came from
Attached to the bracket for the engine stand
On the stand
Locking tools in
Started taking the timing gear off. This is a new one This is the tensioner roller and you can just see that there is a threaded insert stuck on the bolt. The threaded insert should have stayed in the engine but it appears the thread of the bolt is a bit mashed so it took the insert out with it. This is going to be 'interesting' to repair...
Whoever gorrilla'd the tensioner bolt apparently attacked the cam sprockets with a lump hammer too
Drained the remaining coolant from the block. Its a good sign that both drains are clear. Oil cooler drain first
passenger side drain - this drain is almost always blocked, but on this engine it runs free
The vac hoses are completely perished so I'll replace those
I left the oil draining overnight, ready for tomorrow
ID:	21059   Click image for larger version
ID:	21060   Click image for larger version
ID:	21061   Click image for larger version
ID:	21062   Click image for larger version
ID:	21063   Click image for larger version
ID:	21064   Click image for larger version
ID:	21065   Click image for larger version
ID:	21066   Click image for larger version
ID:	21067   Click image for larger version
ID:	21069   Click image for larger version
ID:	21070   Click image for larger version
Old 1st April 2019, 08:40 PM
4 hours of cleaning...
I pulled the oil cooler housing off. The plastic pipe had already cracked. That's getting replaced with an aluminium one.
Yeuch
I really don't know why these engines collect sand between the inlet manifold and the head. They all have it, and one has to be extremely careful when taking the manifold off to not get any down the inlet ports
Flange cleaned up and the inlet ports protected
There was evidence of coolant leakage down the back of the block so I pulled the water pipes off the back of the heads. Just as well I did since one o-ring had turned to fluff and the other was already leaking.
Cleaned up the valley
Breather cover removed - the gasket on this is the source of all the gunge in the valley and also all the oil down the back of the block. There's a little drain hole on the left of the pic where everything that leaks from here escapes down in to the bellhousing
More grub
2 gallons of degreaser later...
ID:	21078   Click image for larger version
ID:	21079   Click image for larger version
ID:	21080   Click image for larger version
ID:	21081   Click image for larger version
ID:	21082   Click image for larger version
ID:	21083   Click image for larger version
ID:	21084   Click image for larger version
ID:	21085   Click image for larger version
ID:	21086   Click image for larger version
ID:	21088   Click image for larger version
ID:	21089   Click image for larger version
ID:	21090   Click image for larger version
ID:	21091   Click image for larger version
ID:	21092   Click image for larger version
Old 1st April 2019, 08:47 PM
So, this threaded insert for the tensioner roller...
I sacrificed a 10mm socket to make a tool to remove the insert from the thread
It fits like this
The insert came off with a little persuasion
Whoever fitted the last belt didn't bother to clean the schmutz out of the thread. They just gorilla'd the bolt in and it got stuck. There's actually no damage to the thread - it just needed cleaning
Made an assembly tool to put it back in the block. It will be held in with Loctite 638 retaining compound
Screwed in to the block and permanently bonded with Loctite.
ID:	21094   Click image for larger version
ID:	21095   Click image for larger version
ID:	21096   Click image for larger version
ID:	21097   Click image for larger version
ID:	21098   Click image for larger version
ID:	21099   Click image for larger version
Old 2nd April 2019, 09:40 AM
Let’s name and shame, shall we? The “gorillas” who did the last belt change were from AudiTechnik in Glasgow. Thanks guys!
Old 2nd April 2019, 08:54 PM
There's something compellingly voyeuristic in these threads
Old 2nd April 2019, 09:54 PM
Chain tensioners.
Since the engine is on the stand I can rotate it 45° so the head is level. This makes the tensioner swap an order of magnitude easier than doing it in the car with the head at 45°.
Not quite so spotless inside as Stephens! This is fairly normal for a 185K mile engine.
Removed the first set of cam caps. The bottom left one is removed even though the cam doesn't come out, since this leaves space to swing the tensioner out.
The cam journals are in perfect condition, despite the gunge
Bizarrely, even though the tensioners rattle on startup, the pads in this one are barely worn
The new tensioner in its box. There really ought to be an angelic choir or fanfare opening this up
Ta dah!
The passenger side cam is a pain because the roller lifters push it off to one side as it's tightened down
This is the culprit
Rather than just using the two main caps to pull it down in to the head, I use all four, plus a technique I've developed which I can't photograph with only two arms!
Back in place
It goes back in with the timing marks slightly off as the lifter pushes it out of position while the tensioner is compressed with its locking tool
I mark each bolt as I torque it up. 5Nm then 90°, so two marks on each bolt.
New oil seals
A genuine VW special tool 3366! This compresses the tensioner so it can be removed or inserted
With the tensioner locking tool removed the spring pressure pulls the chain tight which pops the cam back in line
Cover cleaned up and back on with a new gasket
The driver's side is exactly the same procedure but much easier as it isn't trying to open any valves so it just drops back in place.
ID:	21116   Click image for larger version
ID:	21117   Click image for larger version
ID:	21118   Click image for larger version
ID:	21119   Click image for larger version
ID:	21120   Click image for larger version
ID:	21121   Click image for larger version
ID:	21122   Click image for larger version
ID:	21123   Click image for larger version
ID:	21124   Click image for larger version
ID:	21126   Click image for larger version
ID:	21127   Click image for larger version
ID:	21128   Click image for larger version
ID:	21129   Click image for larger version
ID:	21130   Click image for larger version
ID:	21131   Click image for larger version
ID:	21132   Click image for larger version
ID:	21133   Click image for larger version
ID:	21134   Click image for larger version
Old 3rd April 2019, 07:42 AM
Fascinating stuff!
I notice the new pads are a different colour to the old ones; are they made of a different material or is that just how they look when they are clean!?
