Old 16th September 2011, 08:08 AM
Godders Godders is offline
Does anybody have the part numbers needed to swap over from the fixed handset to the bluetooth ?
I'm not bothered about the rsap functionality, I just want to be able to pair the phone with the car and use the MMI / Multi func steering wheel.
ETKA isn't too clear and Audi are clueless, all I got from the parts chap was "that wouldn't be an Audi approved upgrade !"
2003 D3 A8 4.2 Atlas Grey -
Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid
After: LPG, AMI with HDD
Pending: DVB-T Tuner & fixing niggles
Old 16th September 2011, 11:31 AM
A8 Doc A8 Doc is offline
You can use quite a few modules in all honesty, Mine was a Q7 one. As long as it's for the early MMI high systems (Not A4) from an A6, A8 or Q7 you are generally fine.
Then rerun your 5570 updates through to ensure all is well.
Old 16th September 2011, 12:59 PM
Thanks, none on eBay at the mo so will keep looking.
Looking round ETKA it looks like I need 4E1 862 335, does that part number look right ?
If so what other bits would I need to install ?
I'll give TPS a call to get a price - I'll sit down before dialling
Old 16th September 2011, 04:06 PM
You could also try craig @ tclsatnav.com for a fitted price.
Or kufatec.de
Assuming it comes with the connector block, you need nothing apart from tools.
Old 16th September 2011, 04:08 PM
Or kufatec.de
TPS will order you connector block, very cheap. £1 I think!
Old 5th October 2011, 11:07 PM
Bigmaxy Bigmaxy is offline
Hi All.
Currently figuring out what parts I require to do the same thing. Replace the fixed motorola bluetooth with a non-rSAP factory bluetooth module.
Just not clear on what is required as far as the connectors are concerned. Would probably be clearer when I have everything laid out in front of me, unfortunately we don't have an Audi dealer nearby to order the required connector from so I need to do it in advance.
Where I am confused.
The motorola module has a 42-pin connector
I assume the new module has a 54-pin connector.
What is this 36-pin connector mentioned earlier? Is it some adapter that was included in the car of the OP and I don't need to worry about it?
I'll most likely be ordering a reversing camera retrofit kit from Kufatec so might try to order this 54-pin connector also. (just the connector, not the BT kit)
Would it be the 8K0 051 592 mentioned earlier, from what I have seen, that is a harness for the AMI, prob has the 54-pin attached also. Can the 54-pin be ordered by itself?
Sorry for all the questions. Just want to get it right and not have to be waiting for further parts down the track.
Also, are any changes required within VAGCOM to let the car know the motorola is gone and replaced by the standard BT kit?
Old 6th October 2011, 03:05 PM
Although it's a 54-pin on the unit itself, there was only a 36-pin connector in the plug, sounds crazy, but the other pins aren't used anyway.
Car regonises the unit straight away, but you may need to go in with VCDS and let it know it's a BT kit rather than the Motorola.
