Old 3rd September 2021, 09:15 PM
No, those are the facelift versions on eBay. Very different if you are familiar with them.
The originals are the ones to have, the centres are rare as rocking-horse poo!
Old 9th September 2021, 08:41 PM
Fuel line clips all replaced
The fuel line from the filter was very crusty so I replaced the banjo fitting and hose, along with the filter of course.
New TRW brake hoses
This rear brake line is very crusty so will also be replaced
Brand new rack-side PS pressure hose, plus refurbished front pressure hose and return.
Fitted
Nice of Audi to put marks on pipes so they can be lined up
PS hoses fitted with a new clip, and the replacement brake line also in place.
Manual ecu on the left, auto on the right...
ID:	27170   Click image for larger version
ID:	27171   Click image for larger version
ID:	27172   Click image for larger version
ID:	27173   Click image for larger version
ID:	27174   Click image for larger version
ID:	27175   Click image for larger version
ID:	27176   Click image for larger version
ID:	27177   Click image for larger version
ID:	27178   Click image for larger version
Old 9th September 2021, 08:51 PM
Remember how the Murple's mangled gearbox was missing its sump magnets?
I found one of them stuck to the torsen diff
I've dismantled the tail section of the dead gearbox to fit the casing to the PF's gearbox in order to solve the broken brackets, so this bit will get cleaned up and swapped over.
Old 10th September 2021, 07:51 PM
S81 S81 is offline
I don't claim to know anything about the inside of the gearbox , question is how do you think in made its way in there ,then final question is was there normally 2 sump magnets and if so were do you think the second ones gone
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 10th September 2021, 08:53 PM
Further investigation has revealed that there is a slot in the casing for a magnet in the rear diff housing so I suspect that the magnet fell out of the slot while I've been moving around the dismantled bits of the gearbox, and it stuck to the nearest steel thing which was the torsen diff. The three from the ATF sump are still missing.
Certainly whoever 'rebuilt' the murple gearbox never bothered opening the rear casing or replacing the bearings as they are very loose.
The torsen housing coming off the PF box:
Nice clean torsen. You can see the slot for the magnet directly at the bottom of the casing. The magnet is still in place in this one.
PF end housing on the left, murple housing on the right. You can see the two bosses on the right hand one which have been broken off the left hand one.
320k mile never-opened casing with bearings and spur gears removed.
100k mile probably-opened casing with the bearings still in place. These will all be swapped in to the murple's casing and reassembled.
ID:	27181   Click image for larger version
ID:	27182   Click image for larger version
ID:	27183   Click image for larger version
ID:	27184   Click image for larger version
Old 10th September 2021, 11:17 PM
27litres's Avatar
27litres 27litres is offline
What's the hall effect sensor and sensor ring on the Torsen diff for? Not Speedo is it?
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 11th September 2021, 08:29 AM
Output speed measurement by the TCU, to make sure that input rpm and gear selection are giving the expected result.
When the gearbox fails and throws a 'gear ratio incorrect' code, its the reading from this sensor that allows the TCU to determine that something is wrong in the clutch packs.
