D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc |
So the one option I decided I wanted that I don't already have was a heated wheel ready for the no doubt now unseasonably mild winter (if it is warm, you can thank me!), I have managed to source a heated wheel and switch and looking at Elsa I need a new slip ring and I am good to go.
Looking at VCDS I currently have 4H0 953 568 A fitted (module 16), does anyone have the correct part code for a slip ring to support both ACC and a heated wheel, I don't have lane departure warning. Thanks in advance ![]() |
The only slip ring I could find is 4H0953568H which supports heating (PR-1XT/2ZD) ACC is supported on the steering col. combi switch assembly.
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 24th August 2016 at 11:14 AM. |
Edit: Just read in your original post you've got the switch
![]() Also, it shows a different part number for the switch for steering column adjustment, just thought I'd let you know. 4H0953551A - heated 4H0953551B - non heated
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 24th August 2016 at 12:12 PM. |
Thanks for the reply, has confirmed my thoughts I needed a H suffix slip ring, will now watch ebay.de to wait for one at the right price hopefully before the winter starts!!
I got a wheel, with cowl and switch for €165 which I'm happy with, the slip rings seem to sell for between €40 and €150 depending on the seller, so happy to wait for the right price as I certainly don't need heat in this weather!!!! Looking at the wiring diagram, I may need to run a wire from the switch to the control module if it isn't already in the loom, that aside looks like pretty much plug and play. I've never been able to work out how to get a part code based upon PR code, so thanks again ![]() |
can you explain me where from u both taking this information, what elsa you using and where I can get one, thanks
Audi A8 D4 4H 2012 3.0tdi Quattro 8spd ZF 8HP55a |
http://r.ebay.com/5GpT3D |
Thanks for checking, I may well take a punt on it anyway. I suspect that B was the original part code to include heating, and has been superseded by H....
