D2 - Everything else Anything that doesnt fit elsewhere |
![]() Quote:
Hey just looking at your photo's there David and that jack that folded on you is different than mine, are the jacking points different on the FL than PF or that jack you have is from an A4. The jacking point has some steel in it and the locator on the jack has a magnet so it's easier to keep it in the jacking point. Not that it makes much difference as the 8 ones fold aswell, but i don't think that's the jack for the car.
Had a quick look on ebay and there are a couple of 9000 jacks for sale, also scissor type jacks with a 1.5 ton rating but same problem with modifing it to suit the cars jacking point.
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. |
I think that the body is the same but I can see that the "groove" which positions on the jacking point is continuous on mine but shorter on your jack. The jack is (was!) rated at 1000kg. Jim has kindly let me have his old jack
Thats what made me think that jack was not for the 8, the 8 jack dosent have a groove it actually protrudes out and sits inside the cup on the underside of the car, the part that is gray and looks like a groove is the magnet.
You can get bags that fill from the exhaust, they were used a lot by off roaders for recovery and on soft ground where you would just jack a jack into the ground. I thought about putting one in the boot of the 8 but wasn't sure how soft the underside of the cars is.
David, are our/your 2 jacks identical? If so, it's highly unlikely that we both had the wrong jack isn't it?
![]() Quote:
Looking on ETKA there are 4 part numbers for jacks, depending on year and spec, as follows:
Up to chassis number 4D-x-005 950 is 4D0 011 031C From 4D-x-005 951 is 4D0 011 031D There are then 2 alternatives for the heavier cars. Jack listed for the 3.3 diesel and 6.0 W12 is 4D0 011 031F Jack for armoured model is 4D0 011 021B Thought those might be helpful for people hunting for a stronger/replacement jack. Or wanting to ID what they're got already.....assuming the part number is actually stamped on the jack! The 2 stronger options aren't shared with any other Audi - didn't check the standard jacks but guessing due to weight and material they won't be either. Adrian
My late FL jack looks (if my memory is working) very much the same as my PF one, and I wouldn't ever use either!
Part number stamped on it is 8D0 011 031C, which may actually be from an A4? ![]() No magnet, just a big nylon lug with a groove in. Rated 1000kg as usual.
Ah right then there you go, slight difference to design between PF and FL.
So it was a redesigned jack that was as rubbish as the one it replaced. Well at least the designers were being consistent.
Its bad enough using them under "ideal" conditions - what about trying to change a wheel on the motorway with the buffeting from the traffic? That'll be enough to put sideways force on the jack and collapse it. The trouble is, what do you use instead of the jack provided? I dont want to be carrying around a trolley jack. The armoured vehicle up-rated jack (4D0 011 021B)
(as Jim has) seems to be a better option and it fits in the stowage.
