Old 18th September 2012, 09:32 PM
Default Solar Roof retrofit - Electrickery
There are 2 elements to retrofitting a solar roof - (1) Fitting the roof panel and (2) hooking up the wiring.
The wiring is conceptually simple.
A normal D2 without solar has a simple +12 constant feed through a 40Amp fuse to the blower motor.
With Solar, there is a relay just before the fuse that switches the feed between +12v or the solar panel depending on the current state of the climate module.
The critical part of this job is the have the correct wiring loom, or at lest remove it from a donor car in a useable fashion. If in doubt contact a8parts for one, although its likely only available as part of whole retrofit kit.
I'll describe in detail how to prepare and fit a loom as you would receive from a8parts.
Firstly, lets examine the retrofit loom:
And a close up on the relay holder:
and from another angle:
Ok, now I'm a stickler for OEM, and that includes wiring. You can join the wiring, but at 40amps there some beefy connections. Instead, I prefer to remove the connecitons properly and reuse them. The place to perform this is at the blower fuse holder - Leave 1 connection in place on the car, and slot the rest of the retrofit loom into the other connector.
The big fuse block can have its connectors removed with some careful manipulation:
You need 2 flat blade screwdrivers to insert into the tabs below so that the connector can be pulled out gentle:
These are the tabs you are aiming to press down using the flatblade. Once pressed down, the connector will pull out from the casing. Leave the fuse holder in the car, remove completely the small length of loom that runs down the 10mm nut at the bottom of the fuse box.
Footwell prepped, stripped back and transmission tunnel covers removed:
You'll need to strip back the roof trims between the middle sunroof controls and the A pillar so that you can run the solar panel connection up the A pillar and into the void above the sunroof controls. This is where the Panel will connect to the retrofit loom.
You'll end up with a bundle of cable in the footwell we'll need to deal with. The main relay panel pulls out with a little care revealing the space where we can install the solar relay
And the relay holder pushed into place. The metal bar is from a pre-wired pre 1997 car, and the solar wiring was present even though there is no solar panel so this bar acts as a permanent bypass to connect the blowers to +12.
Replaced with a relay:
and pushed back into place, and the connector pushed into the 40 amp fuse holder, and it popped back into place
And connect these 2 earth connections together, one from the solar panel, and one on the car - Oddley, this connection is on every D2 - They all seem to be prewired with it.
Then onto the climate module. Remove it completely and find the conenctor block A - Note it is not the connector to the far edge of unit, it is one of the 2 connectors next to an edge connector. Look very closely at the unit and you will see the letters.
This is the one we need to connect to the relay back in the footwell. Pin 14 is memory serves me correctly. The wire presses in, then metal clips wrap around to hold it in securely.
All taped up nicely and ready to plug back in:
And pop the climate back in, then we're pretty much done. Make sure the 2 x 12V constant feeds are connected to the 10mm spade at the bottom of the footwell (where the original blower feed came from) and all should be good. Heres a final reference:
Sorry its a bit rushed... i'm on a laptop and battery is going flat lol.
Any questions, ask
ID:	4759   Click image for larger version
ID:	4760   Click image for larger version
ID:	4761   Click image for larger version
ID:	4762   Click image for larger version
ID:	4763   Click image for larger version
ID:	4764   Click image for larger version
ID:	4765   Click image for larger version
ID:	4766   Click image for larger version
ID:	4767   Click image for larger version
ID:	4769   Click image for larger version
ID:	4770   Click image for larger version
ID:	4771   Click image for larger version
ID:	4772   Click image for larger version
ID:	4773   Click image for larger version
ID:	4774   Click image for larger version
ID:	4775   Click image for larger version
ID:	4776   Click image for larger version
Old 19th September 2012, 04:33 AM
great thanks Ian - I've made it a sticky in upgrades
Old 19th September 2012, 08:15 PM
Very very interesting Ian. Glued at reading.
Old 19th September 2012, 09:01 PM
RanjS8 RanjS8 is offline
Default solar panel install
I agree...very useful and good write up...quite alot involved there but very doable with this guide.
Old 19th September 2012, 09:04 PM
Fingers crossed I've got the wiring I need for mine - not investigated the box full of wiring loom I've got lol
Wonder if the connectors can still be had from Audi if needed?
Old 19th September 2012, 09:15 PM
If you don't have the connectors, you could do it easily with anything else really.The relay is a 373 which there are a few of in a D2 and the rest is just splicing wires.
Old 20th December 2012, 05:55 AM
71camaro 71camaro is offline
Ian, in the top photo should the wire at bottom right labeled as +12v const. be labeled as a ground?
Old 27th April 2013, 01:31 PM
Default Help
I'm just checking my wiring and just getting my head around it. on the top picture bottom right it shows the brown/black wire as constant feed. And on pic 16 I think it shows the same wire onto the plug that goes to climate controller. And on pic 18 does it show the same wire onto the constant 12v feed. Am I right to presume these 85/86 just energise/switch the realy and it doesn't matter which way round they are? Or is it me being Fick! ;-)
Cheers Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 29th April 2013, 10:04 PM
Ok don't panic! sorted! it's all done and working brilliantly
Cheers Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 30th April 2013, 04:59 AM
Well done
